speed supported by WIC-2T
sivakondalarao
My Internet speed is 4Mbps. What kind of serial interface I have to select?
What is WIC-2T serial interface supported speed?
SKRAO
5 Replies 5
imnilesh
hi siva;
on what interface does ISP providing o/p of 4 mbps? you can ask isp to provide it on ether net.
and WIC-2T support upto 2 mbps
HTP.
Nilesh
No Nilesh,
I have gone through the link provided by Devang, it will support upto 8Mbps.
You also please go through it.
SKRAO
amit-singh
Level 8
Level 8
By default, one port in WIC-2T supports 2 Mbps max (synchronous).
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b8b.html
HTH,
-amit singh
That was an informational link from Devang.
Till now i had been thinking that a WIC-2T would not support more than 2 Mbps
Narayan
