Squid Proxy Server with Cisco Router
Hamidsattarrana
Dear All!
I need some guide to configure squid proxy server with cisco router.
I have 1 Cisco router installed in our network CIsco 3845. IP is 192.168.10.1
Squid Proxy Server is in our LAN Network IP is 192.168.10.100
I want to configure it. I want all traffic from Network 192.168.10.0/24 go through Proxy Server 192.168.10.100 then go to Internet.
What configurations I have to do on Router?
Kindly Guide.
Thanks.
6 Replies 6
Mark Elsen
 - Squid supports WCCM  , below is an example of how to set it up on  a CISCO router :
         https://www.cisco.com/c/en/us/support/docs/security/web-security-appliance/118242-configure-wsa-00.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi!
I have configured an ACL to match dns, http & https traffic. Then I am doing PBR next-hop to Transparent Squid Proxy Server (192.168.2.1).
ACL is:
Ip access-list extended web
permit ip any any eq www
permit ip any any eq 443
permit ip any any eq domain
exit
route-map web
match ip add web
set ip next-hop 192.168.2.1
exit
Web traffic is routing to proxy server.
But the strange thing is that proxy server is blocking only http and there is no access logs for https?
I don't know much about wccp or wccp2. My IOS supports Wccp features. But don't know exactly how to implement it.
And does wccp redirect "https" Secure http?
Need suggestion?
balaji.bandi
here is the good guide for Squid proxy config along with router config
https://wiki.squid-cache.org/Features/Wccp2
BB
Does it work with https? Secure Http
depends on your requirement, and WCCP redirection.
BB
As a side note, some squid installation packages are not compiled with the correct flags to permit SSL decryption and caching. Confirm this with the command:
squid -v
...you are looking for '--with-openssl' and '--enable-ssl-crtd'
I wrote a blog post about it recently:
https://cs7networks.co.uk/2020/02/17/squid-ssl-decryption-with-freebsd/
cheers,
Seb.
