Showing results forĀ
Search instead forĀ
Did you mean:Ā
SR 4451
hien.tran2.mil
I have fiber run on port g0/1/0 on this ISR 4451 to a switch. Is there a way only allow 10MB traverse on this port. Thanks
balaji.bandi
Try the below example :  ( i do not have Router in hand to test)
https://www.cisco.com/c/en/us/td/docs/routers/access/800M/software/800MSCG/QoS.html
Also not sure at this stage srr-queue can be used here :
(config)# interface g0/1/0
(config-if)# srr-queue bandwidth limit 99
https://www.cisco.com/c/en/us/td/docs/switches/lan/Denali_16-1/ConfigExamples_Technotes/Config_Examples/Misc/qos/m_qos_monitoring.html
BB
