SR520-ADSL-K9 - Can't even connect to router after power failures
Good afternoon everyone,
I'am a bit newbie at using Cisco products and here is my problem : I have set up a VPN tunnel between 2 Sites (A and B) a few month ago using 2 cisco SR520-ADSL-K9. All was working fine until power failures occured on the sites B (secondary site).
What happened was that none of the ethernet ports were working, excepting during booting, I was then able to ping computers linked to ports Fastethernet0, FastEthernet1, FastEthernet2 and FastEthernet3 but after a few seconds all ports were disabled but my DSL seemed to be working.
So I took back the router home to check it. I managed (I think) to make a factory reset using a serial terminal and following the procedure described here http://www.cisco.com/en/US/docs/routers/access/500/520/software/configuration/guide/520scg.pdf on page 12-10.
Since I did the reset, I thought I would be able to re-use Cisco Configuration Assistant (3.1) to re-configure the router (I am very bad at using the command lines) but I am unable to connect to the router using the supposed default IP : 192.168.75.1 (I set my computer to use 192.168.75.50 IP adress with mask 255.255.255.0). But I can't connect to the router ... even if the Ethernet ports seem to work because green light is on when plugging my cable.
So can someone give me some help to be at least able to connect to my router using CCA ?
For more information, here is what I get when I run "show startup-config" and "show running-config" in terminal console.
I guess the objective is to make the startup-config beeing the running-config, but I have no idea on how to do that ...
Thanks in adavance for your precious help !
show startup-config
show running-config
Router#show startup-config
Using 4812 out of 131072 bytes
version 12.4
no service pad
hostname SR520
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$05di$y2ycn34NGfsSTR1kwa2GO0
no aaa new-model
crypto pki trustpoint TP-self-signed-2778606820
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2778606820
revocation-check none
rsakeypair TP-self-signed-2778606820
crypto pki certificate chain TP-self-signed-2778606820
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.75.1 192.168.75.10
ip dhcp pool inside
   import all
   network 192.168.75.0 255.255.255.0
   default-router 192.168.75.1
ip cef
no ipv6 cef
username cisco privilege 15 secret 5 $1$BowA$Cv/en/m3ERL4MhaSCO6Ba/
archive
log config
  hidekeys
class-map type inspect match-any SDM-Voice-permit
match protocol h323
match protocol skinny
match protocol sip
class-map type inspect match-any sdm-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any sdm-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all sdm-invalid-src
match access-group 100
class-map type inspect match-all sdm-protocol-http
match protocol http
policy-map type inspect sdm-permit-icmpreply
class type inspect sdm-cls-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-inspect
class type inspect sdm-invalid-src
  drop log
class type inspect sdm-cls-insp-traffic
  inspect
class type inspect sdm-protocol-http
  inspect
class type inspect SDM-Voice-permit
  pass
class class-default
  pass
policy-map type inspect sdm-inspect-voip-in
  pass
class class-default
  drop
class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security sdm-zp-self-out source self destination out-zone
service-policy type inspect sdm-permit-icmpreply
zone-pair security sdm-zp-out-self source out-zone destination self
zone-pair security sdm-zp-in-out source in-zone destination out-zone
service-policy type inspect sdm-inspect
zone-pair security sdm-zp-out-in source out-zone destination in-zone
service-policy type inspect sdm-inspect-voip-in
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description WAN via ADSL
pvc 0/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
switchport access vlan 75
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
shutdown
interface Vlan75
description $FW_INSIDE$
ip address 192.168.75.1 255.255.255.0
ip nat inside
ip virtual-reassembly
zone-member security in-zone
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname cisco
ppp chap password 0 cisco
ppp pap sent-username cisco password 0 cisco
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 192.168.75.2 5060 interface Dialer0 5060
ip nat inside source static udp 192.168.75.2 5060 interface Dialer0 5060
ip nat inside source static tcp 192.168.75.2 1720 interface Dialer0 1720
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.75.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 100 remark SDM_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
control-plane
banner login ^CSR520 Base Config - MFG 1.0 ^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Router#show running-config
Building configuration...
Current configuration : 814 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
archive
log config
  hidekeys
interface ATM0
no ip address
shutdown
interface Vlan1
no ip address
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
I think it would be helpful to add the result of the "show configuration" command :
Router#show configuration
version 12.4
no service pad
hostname SR520
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool inside
   import all
ip cef
no ipv6 cef
archive
log config
  hidekeys
match protocol h323
match protocol sip
match protocol icmp
match protocol tcp
match protocol udp
match protocol dns
match protocol ftp
match protocol h323
match protocol icmp
match protocol imap
match protocol pop3
match protocol rtsp
match protocol tftp
match protocol tcp
match protocol udp
match protocol http
  inspect
class class-default
  pass
  drop log
  inspect
  inspect
  pass
class class-default
  pass
  pass
class class-default
  drop
class class-default
  drop
interface ATM0
no ip address
pvc 0/35
interface Vlan1
no ip address
shutdown
interface Vlan75
ip nat inside
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ip http server
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
I just did the following command : copy startup-config running-config
Doing this made the router beeing accessible via network and CCA. But once I reboot the router, I lost this connection and configuration.
Any way to make the router keep the new running-config in memory ?
Thanks in advance !
