SSH -1 username target command is not working on packet tracer
numanmalik101
I am doing a lab on Packet Tracer and I configured SSH on the router and after that, I am trying to access it through the PC command line. when I try to run SSH it gives me an error "Command invalid.". While you can see PC is pinging router using IP address 10.1.1.10.
Please help!!!
Thanks in advance
you should use below command. parameter should be -l (letter L in simple) not the number 1.
>ssh -l cisco 10.1.1.10
good luck
mark this as answer and upvote if this solved your concern
KB
Good luck
KB
good luck
KB
Good luck
KB
thank you soo much.
You solved my problem.
God Bless you
what did you actually configure on the router ? Post the zipped Packet Tracer project (.pkt) file...
