SSH failing authentication but Serial Works
Zygodactyl
I have a Cisco ISR 4431 which i have enable SSH for and locked down to a only respond to single Subnet for SSH.
Weird part is when I try to ssh into the ISR from that subnet I am able to get to the login prompt. However it fails authentication for some reason, but that same user works over a serial connection. Is there maybe a setting for the user i missed or something.
pertainent config lines are as follows
username <redacted> access-class 15
ip access-list standard Limit_SSH
permit 10.92.1.0 0.0.0.255
permit 10.91.3.0 0.0.0.255
permit 192.168.1.0 0.0.0.255
deny any
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class Limit_SSH in
access-class Limit_SSH out
transport input ssh
transport output ssh
line vty 5 15
transport input ssh
16 Replies 16
Yep that is it, aaa policy was messing it up you cannot do local authentication with that for what ever reason once i removed that i was able to authenticate.
It has been a while since i have tested that portion but if i remember correctly if i remove the ACL it starts working.
I will confirm that now.
