SSH failing authentication but Serial Works
Zygodactyl
I have a Cisco ISR 4431 which i have enable SSH for and locked down to a only respond to single Subnet for SSH.
Weird part is when I try to ssh into the ISR from that subnet I am able to get to the login prompt. However it fails authentication for some reason, but that same user works over a serial connection. Is there maybe a setting for the user i missed or something.
pertainent config lines are as follows
username <redacted> access-class 15
ip access-list standard Limit_SSH
permit 10.92.1.0 0.0.0.255
permit 10.91.3.0 0.0.0.255
permit 192.168.1.0 0.0.0.255
deny any
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class Limit_SSH in
access-class Limit_SSH out
transport input ssh
transport output ssh
line vty 5 15
transport input ssh
Yep that is it, aaa policy was messing it up you cannot do local authentication with that for what ever reason once i removed that i was able to authenticate.
16 Replies 16
GRANT3779
If you are not using aaa then add login local under the vty lines
Line vty 0 15
Login local
balaji.bandi
Serial connection means, on console ?
if this is console you do not have any config on Console port.
what kind of authentication you using AAA with Local authentication ?
BB
Correct it should be local authentication and i believe AAA is enabled.
Can you post that AAA config to look. also post the login error of possible.,
BB
Basically blank
aaa new-model
aaa authentication login default local enable
aaa authorization exec default local
Whoops did one thing wrong, i am actually getting a refused connection from the device not a failed authentication.
I was connecting to the IP of a different device.
But still a similar issue
What is the status at the moment? Are you getting as far as being prompted for a username or can you not get as far as that?, e.g connection refused completely?
No prompt for authentication, i get a refused connection.
so i am accessing it from that 192.168.1.1/24 vlan which if i wrote the ACL right should be allowed.
But some how I am getting a connection refused error.
It is set to use aaa and they is an explicit deny all after the three allowed VLANs
Have you done all the initial SSH config, e.g create crypto key etc.?
Have you tried telnet for testing or remove the ACL to check if this is the issue?
It has been a while since i have tested that portion but if i remember correctly if i remove the ACL it starts working.
I will confirm that now
Once i remove the ACL i am able to get to the login prompt however somehow it fails authentication so i probably have not configured SSH correctly.
This is the entire config with password and external IPs redacted
Current configuration : 5120 bytes
! Last configuration change at 18:58:09 UTC Tue Jul 23 2019 by <redact>
version 15.5
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname ISR4431
boot-start-marker
boot system bootflash:/isr4400-universalk9.03.16.05.S.155-3.S5-ext.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
aaa new-model
aaa authorization network default local
aaa session-id common
ip vrf Internet
 rd 2:2
ip vrf MPLS
 rd 1:1
ip domain name LWGINC.com
subscriber templating
license udi pid ISR4431/K9 sn <redact>
username <redact> access-class 15 secret 8 <redact>
redundancy
 mode none
interface GigabitEthernet0/0/0
 description LAN-VRF-MPLS
 ip vrf forwarding MPLS
 ip address 10.92.1.254 255.255.255.0
 negotiation auto
interface GigabitEthernet0/0/1
 description LAN-VRF-Internet
 ip vrf forwarding Internet
 ip address <redact> 255.255.255.224
 negotiation auto
interface GigabitEthernet0/0/2
 description WAN-VRF-MPLS
 ip address <redact> 255.255.255.252
 negotiation auto
interface GigabitEthernet0/0/3
 description WAN-VRF-Internet
 negotiation auto
 vrf forwarding Mgmt-intf
 ip address 10.100.100.254 255.255.255.0
 negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0/0/0
<redact>
ip ssh version 2 ! ! ip access-list standard Limit_SSH permit 10.92.1.0 0.0.0.255 permit 10.91.3.0 0.0.0.255 permit 192.168.1.0 0.0.0.255 deny any ! access-list 1 permit 10.92.1.0 0.0.0.255 access-list 1 permit 192.168.1.0 0.0.0.255 ! ! ! ! ! control-plane ! ! line con 0 stopbits 1 line aux 0 stopbits 1 line vty 0 4 access-class Limit_SSH in access-class Limit_SSH out transport input ssh transport output ssh line vty 5 15 access-class Limit_SSH in access-class Limit_SSH out transport input ssh transport output ssh ! ! end
accidentally double posted
Are you using VRFs?
If so, try adding the following
access-class Limit_SSH in vrf-also
that does not seem to help for some reason i am getting authorization failed which i think would be related to the AAA policy not being setup correctly. from my understanding this means it is passing authentication but the user for some reason is not authorized to connect via SSH. note i am not using  tacacs+ i am just trying to authenticate with a local device user. is there maybe something i am missing here
aaa new-model
