SSH into ASR 4321 Not Working
NETAD
Level 4
Level 4
Hello, running into a weird issue with SSH into a router an ASR 4321. It's timing out from remote sites while it works from the local site. We can ping the router, so we know routing is there but ssh and telnet timeout. Not ACLs at all on the router. I captured and attached is what I see. Please assist. Router is running 15.5(2)s
11 Replies 11
marce1000
 - What if the remote sites impose restrictions for reaching your ASR trough SSH (such as fire-walling for both Internet and  or Intranet traffic).
 M.
There isn’t any. We’re able to ssh to the switch downstream from the router just fine.
Hello
So you can ssh/telnet from the rtr but not to the router correct?
sh management-interface
sh run | sec line
Kind Regards
Paul
laporte-r1#sh run | sec control-plane
control-plane
laporte-r1#
jmperlewitz
Check which protocols are allowed for the control plane..  You can allow only explicit protocols and sources to the control plane which does not use ACLs.  Can you paste the following:
control-plane
laporte-r1#
Nothing there
curious if you ever figured this out? I'm having a similar issue where i can log into the router from the same segment in the Mgmt-vrf or local peerings.  Although, I can't ssh to this router from remote networks but I can get into routers/switches from remote networks in the same segment.
If you would post a sanitized copy of your configuration we might be better able to identify the issue.
Rick
Will do later today. Thanks Rich.
I will take a look at it when you get the config posted.
Rick
Still unable to. I will post my config and see if Rich can help.
