SSH suport on these Switches.....
divyendu_bhatt
Dear All,
I have the following Version of IOS on my switches I need to know can I enable SSH on these IOS or I need to Upgrade
Version 12.2(25)SEB4
Version 12.1(19)EA1c
Version 12.2(20)EW
Version 12.2(20)EX
Version 12.2(25)SEC
Version 12.2(25)SEC
Version 12.1(19)EA1d
Version 12.2(20)EX
Thanks in advance
Divyendu Bhatt
7 Replies 7
Richard Burts
Divyendu
For support of SSH the thing that is important is the feature set of the code more than the version of the code (it needs to be a feature set that supports encryption). So we can not look at the versions numbers that you have posted and know whether they support SSH or not. You would probably need to give us the full image name to allow us to determine whether SSH was supported.
Rick
Rick
The images should be a K9 image to support SSH.
Just check whether you see K9 in the IOS file name. you can also try generating an RSA key to check support
crypto key generate rsa
If SSH is supported the command would be accepted
HTH, rate if it does
Narayan
Hello Narayan,
I have K9M and then rest are images are given below
Software
C3750 Software (C3750-ADVIPSERVICESK9-M)
C3560 Software (C3560-I5-M)
Catalyst 4000 L3 Switch Software (cat4000-I9S-M)
C3560 Software (C3560-IPBASE-M)
C3750 Software (C3750-I9-M)
Thanks for the great help.
Divyendu
Divyendu,
Your 3750 would definitely support SSH
The IP base versions will not support SSH
Narayan
Hello Rick,
Thanks for the help in advance the info I have it with me is the IOS version which is given below :
Software
If you can help from the above its gona be great.
regards
Divyendu
Divyendu
As Narayan says in his response the first 3750 clearly will support SSH. It does not look like the other switches (including the second 3750) will support SSH without a code upgrade.
Rick
Rick
Hello Rick,
Thanks for the support now the next task i got is to upgrade this.....Gr8 help mannn
Thanks a lot ..
Divyendu
