stable small office router with VPN access
miroslaw len
I am looking for any stable router for small office ( few servers accesible from internet ) for max 100 persons.
I would like to give mobile users possibility to use VPN channels in more than 5 quantity. Is that possible?
Would be best to have redundant WAN - either on backup USB port, or second WAN ethernet.
Which models would be good for me?
regards
6 Replies 6
miroslaw len
bump
rizwanr74
Level 7
Level 7
If you are looking router with dual routable-interfaces, then you have to go with Cisco 2900 series routers.  Cisco 2901 will do the job.
http://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/data_sheet_c78_553896.html
Which has three routable  interface, which can be used for two WAN connection and third for internal connection to a switch.
thanks
thank you for your reply,
Its big device :) I suppose that great :)
But is there any smaller? For smaller environments if possible?
thank you
"Would be best to have redundant WAN - either on backup USB port, or second WAN ethernet."
You stated above for redundant WAN connection, which requires two routable interfaces and a third additional interface to connect to your internal switch.
thanks
thank you for your answer
so would be simpler if I will decline th USB port? As I know from long time the rv082 Cisco/Linksys devices also have two WAN ports.
regards
Linksys SOHO device is not an enterprise-class device to support a hundred users, it will slow down your connection to Internet when 100 users request for connection.
SOHO device are meant to use for 5 to 10 years at most and I am not so sure of SOHO device's dual redundant WAN connection capability.
thanks
