Statement order in Standard ACL 3750. Plz help
alexc2010
Hi All,
The switch (3750) running 12.2(50)SE3 has the problem that ACL 20 is not in the order in which it was created.
  the order in which I enter the aclis different than the one that is displayed in the show run and the show access-list
  can someone let meknow how itworks?
usasw1(config)#access-list 20 permit 14.18.10.10
usasw1(config)#access-list 20 permit 14.18.10.28
usasw1(config)#access-list 20 permit 14.18.10.20
usasw1(config)#access-list 20 permit 13.20.13.20
usasw1(config)#access-list 20 permit 13.40.18.31
usasw1(config)#access-list 20 permit 13.20.28.40
usasw1(config)#access-list 20 permit 13.40.3.142
usasw1(config)#access-list 20 permit 13.20.28.1620
usasw1(config)#access-list 20 permit 13.20.10.148
usasw1(config)#access-list 20 permit 13.20.15.40
usasw1(config)#access-list 20 permit 12.25.10.243
usasw1(config)#access-list 20 permit 13.20.10.10
usasw1(config)#access-list 20 permit 14.18.10.55
usasw1(config)#access-list 20 permit 14.18.10.125
usasw1(config)#access-list 20 permit 13.20.15.15
usasw1(config)#access-list 20 permit 13.40.34.57
usasw1(config)#access-list 20 permit 12.16.126.26
usasw1(config)#access-list 20 permit 13.40.32.48
usasw1(config)#access-list 20 permit 13.40.32.82
usasw1(config)#access-list 20 permit 13.40.10.125
usasw1(config)#access-list 20 permit 14.18.10.40
usasw1(config)#access-list 20 permit 13.20.13.10
usasw1(config)#access-list 20 permit 13.20.13.15
usasw1(config)#access-list 20 permit 13.40.2.37
usasw1(config)#access-list 20 permit 14.18.23.246
usasw1(config)#access-list 20 permit 14.20.135.165
usasw1(config)#access-list 20 permit 12.16.10.125
usasw1(config)#access-list 20 permit 12.16.12.201
usasw1(config)#access-list 20 permit 13.40.32.30
usasw1(config)#access-list 20 permit 15.14.10.58
usasw1(config)#access-list 20 permit 13.27.10.10
usasw1(config)#access-list 20 permit 13.20.24.31
usasw1(config)#access-list 20 permit 14.20.10.236
usasw1(config)#access-list 20 permit 15.140.10.14
usasw1(config)#access-list 20 permit 15.140.10.15
usasw1(config)#access-list 20 permit 14.20.103.203
usasw1(config)#access-list 20 deny   any
C3750-2#show access-lists 20
Standard IP access list 20
    50 permit 13.40.18.31
    60 permit 13.20.28.40
    70 permit 13.40.3.142
    80 permit 13.20.28.1620
    270 permit 14.18.23.246
    10 permit 14.18.10.10
    30 permit 14.18.10.20
    40 permit 13.20.13.20
    10 permit 12.25.10.243
    12 permit 13.20.10.10
    280 permit 14.20.135.165
    200 permit 12.16.10.125
    300 permit 12.16.12.201
    13 permit 14.18.10.55
    140 permit 13.20.10.10
    23 permit 14.18.10.40
    240 permit 13.20.13.10
    250 permit 13.20.13.15
    260 permit 13.40.2.37
    310 permit 13.40.32.30
    320 permit 15.14.10.58
    200 permit 13.20.10.148
    10 permit 13.20.15.40
    330 permit 13.27.10.10
    340 permit 13.20.24.31
    150 permit 14.18.10.125
    160 permit 13.20.15.15
    170 permit 13.40.34.57
    180 permit 12.16.126.26
    120 permit 13.40.32.48
    200 permit 14.18.10.10
    350 permit 14.20.10.236
    210 permit 13.40.32.82
    360 permit 15.140.10.14
    370 permit 15.140.10.15
    380 permit 14.20.103.203
    450 deny   any
Any help on this is highly appriciated. Thanks in advance.
REgards
Alex.
raymondkong
Typo here ==>
Don't know if that cause the problem though.
In standard ACL's the order is random and I have never heard an explaination why. Since it is a standard ACL it doesn't matter too much as they are generally used for granting access versus packet filtering. If you must have a specific order you'll need to use an extended ACL.
Hope it helps.
I think , I have heard about this somewhere , the problem is that The Access-list Sequencing No.'s are not supported for old numbered ACL's  be it standard or extended , but if you create the access list as a Named Access List then the sequencing works. so if you do :-
access-list 20 permit a.b.c.d 0.0.0.255
access-list 20 permit a.b.c.x 0.0.0.255
Then the sequencing doesn't work but if you do :-
ip access-list standard XXX { XXX here could be number or name whatever you like )
10 permit a.b.c.d 0.0.0.255
30 deny any
This should work as far as sequencing is concerned as per my knowledge.
Manish
