Bookmark
Subscribe
1624
Static ip scenario
050878james
Hello !!
I have some questions about BRAS and ip address assigment to users.
Let`t say we have the interface below on our BRAS 7200.
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 80.80.80.1 255.255.255.0
So the IPDSLAM is connected to this 7200 series router, and all users are in the same vlan. Now how can I assign one ip address for 1 user, and don`t let him use another ip address than one we assigned to him. If he tries to use another one than he should not be able to acces the network.
I know about one isp which did this on the same way, and the best of all is they have not binded ip address to mac address, because their customers can use any router/modem they just want, but they can ONLY use the ip address they are assigned from this isp.
How is this possible ? we will not use PPPoE or PPPoA because this makes many problems for our customers when they need to restart their equipment, the authentication is not allways successfull.
Any idea ? what is the best way to accomplish this goal ??
I`ll not forget the rating !
Thank You
Best regards
Confirm first that you have set the DLSAM to map individual lines into an individual vlan. Create the subinterface, add the correct vlan ID as encapsulation, assign any IP address and enter static route for the remote, pointing to subinterface. That's it.
17 Replies 17
paolo bevilacqua
This may not be so easy to meet. Anway, I think it's not possible for sure, as long you have a single vlan for all dsl pvcs. You should set the dlsma so maps each line to a vlan, then find the best configurtion there, I'm looking in more detail on how this would be possible, so ls stand by.
Hi again !!
Thank You for reply, I really tried to find a solution for this scenario, but it seems that I had no luck this time :( I hope that You can figure it out. I was thinking about static arp table, but not useful at all because this is used to ensure that user receives the same ip from dhcp each time it ask for it, but this will not pervent user to type another ip address manually and connect to the network.
Thank You I am waiting for some answer and I hope that You can find a solution.
Best regards
One way could be this (I can't test that yet).
Configure the IP DSLAM to map each PVC that need a static address in a separate vlan.
Under the subinterface, configure a private address/mask, that is ok as long doesn';t overlap with others.
Then configure as many static routes as necessary with mask /32 for the static address, pointing each one to the corresponding subinterface.
Could I ask You for one "sample example config" that is working ?
I`ll be out of the office for 1 hour, but than I am back !!
Thank You very much for helping !!!!
I really need to fix this isue.
Best regards
hmm, well let me think little about it, so I`ll let You know my understanding...
Looks very interesting solution......
Thank You very much !!!!
Best regards
This one should work by virtue of proxy arp. The PC sends ARP for gateway address, and even if this address is not the one of the interface receiving ARP, router will reply with a MAC address.
Thanks for the nice rating and let us know how it goes!
You`re welcome !!!
Well hope that I have right understanding now.
Let say we have one sub-interface:
int fa/0.010
description dsl_cust
ensapsulation dot1q 10
Than we configure the IPDSLAM for example,
we configure switch port number 1 on the
IPDSLAM as a member of the VLAN 10, but hmm
I am still little confused here.. because this dsl user needs to use the ip 80.80.80.1
as the gateway and he can use 80.80.80.2 as
his static ip address. But I still don`t understand how I can (fix) this ip, so he can`t use for example 80.80.80.3 og .4 not just .2
I am really trying to understand but it is not that easy.
Thank You for helping !! any better explanation using config maybe ?
Best regards
Well for 20 min ago I asked one of my old friends to test something for me. He is connected to the ISP which assigns static ip addresses for its customers.
Let`s say this is the ip address my friend got from his ISP:
ip address 80.50.50.3
subnetmask: 255.255.255.0
gateway: 80.50.50.1
And he is only able to use ip address 80.50.50.3 and not another ip addresses, even if this is a big subnet. Another customer got 80.50.50.4 and both of these customers uses the same gateway. But they can`t use another ip address than one ISP assigned to them.
My friend have Cisco ASA 5505 and he NAT`s to his internal LAN, so his lan ip of the ASA is 10.10.10.1 255.255.255.0.
And than I asked him to trace google.com
so after the trace was successfull:
As first HOP he got the ip address
1 10 ms 7 ms 6 ms 10.227.2.1
And if You see this ip address is not on his network, this is ip address from IPDSLAM I think ?? and why he receives this ip address, because as first hop he should get the ip address 80.50.50.1, because this is his GATEWAY he got from his ISP and this ip is used in the default route on his ASA, but not instead of ip 80.50.50.1 he gots this ip as first hop 10.227.2.1
So they must use one or another router on the PSTN which is connected to IPDSLAM or this is ip of the IP DSLAM.
Do You understand this scenario ??? maybe this will give You idea how to explain it to me ??
Thank You !!!!
I AM REALLY SORY for long post, but I like to describe every detail, so You understand what I mean.
Best regards
James,
You have observed in act, what I was suggesting you to try.
He gets an "off-subnet" first hop address because the router interface doesn't have the address configured as GW on the ASA. Instead that interface has a private address picked as ISP likes.
But due to proxy-arp, or call it router magic, no other address outside the static route will work on that vlan. You can also add more addresses to a customer, if you want.
Good luck!
Well I`ll try it tomorrow, and I`ll let You know !!
Thank You again !!
Best regards
Hello again !!
Well I really tried but no success, do You have any possibilities to create a short sample how the config exactly should look like ?? on the BRAS (Router) ? where the IPDSLAM is connected to.
Thank You for helping !!!
I`ll rate the answer !! hope You`ll create the short sample.
I`ll really appreciate Your help !!
Best regards
James
this is not possible without the use of an radius assigned pool. which will need pppoe or pppoa.
Steve
Well, than how this ISP I was talking about fixed these issues ? They are just giving their customers "static ip address" "subnetmask" and "gateway" så than they are on the network, no PPPoA and no PPPoE. So this is 100% possible, but I just need one example from someone who did this before.
Thank You
Best regards
