Static Nat - access local web server via internet
modal
I'm trying to enable acces of my local web server over the internet
I can access the server locally via the ip address (http://192.168.1.7) on port 80
I have created an A record and pointed it to the public IP address x.x.x.76, which is within a block with my main public ip for internet x.x.x.74
However, when i try to access the web server over the internet, i fail
I have attached my router config
Using 4396 out of 262136 bytes
version 15.2
hostname test
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no logging console
no aaa new-model
ip cef
ip dhcp pool TEST
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 4.2.2.2
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
ip address x.x.x.74 255.255.255.248
ip nat outside
duplex auto
speed auto
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool TEST x.x.x.74 x.x.x.74 netmask 255.255.255.248
ip nat inside source list 23 pool TEST overload
ip nat inside source static tcp 192.168.1.3 25 x.x.x.74 25 extendable
ip nat inside source static tcp 192.168.1.3 110 x.x.x.74 110 extendable
ip nat inside source static tcp 192.168.1.3 443 x.x.x.74 443 extendable
ip nat inside source static tcp 192.168.1.7 80 x.x.x.76 80 extendable
ip nat inside source static tcp 192.168.1.7 443 x.x.x.76 443 extendable
ip route 0.0.0.0 0.0.0.0 x.x.x.73
access-list 23 permit 192.168.1.0 0.0.0.255
control-plane
ate 20000 1000
end
Kindly help
I've labbed it up and I can't get it to fail with your config. Can you post "sh ip nat translat"?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
37 Replies 37
Lei Tian
Remove the server IP from dynamic nat access list, and try.
HTH,
Lei Tian
Sent from Cisco Technical Support Android App
Thanks Lei
I'm not really a CISCO guy though
How should i do that?
Mike
Michael,
Try removing this line:
with "no ip nat pool TEST x.x.x.74 x.x.x.74 netmask 255.255.255.248"
HTH,
John
Thanks John
I'm currently out of town but can acces the router via SSH & telnet
I cannot remove/destroy it as the pool is in use
Michael
HTH,
John
Dear John
sh ip nat translations
Pro Inside global      Inside local              Outside local                     Outside global
--- ---                       ---                           192.168.1.7                       197.221.128.76
tcp x.x.x.74:1033    192.168.1.2:1033      79.143.167.6:26394            79.143.167.6:26394
tcp x.x.x.74:1043    192.168.1.2:1043      186.38.22.148:6881           186.38.22.148:6881
tcp x.x.x.74:443      192.168.1.7:443         ---                                    ---
Its a much longer list, just picked out a few lines
Is there a firewall between your router and this server? Do you have a translation for port 80? I see 443, but not 80. Does 443 work if you try to telnet into the port from the outside? (telnet x.x.x74 443). If the screen clears with a cursor in the upper left, it's open and you're getting to the server.
HTH,
John
Thanks John
But i'm unable to telnet into it ... connection failed
I'm thinking it could be with  .... ip nat pool TEST x.x.x.74 x.x.x.74 netmask 255.255.255.248
i only specified one Public IP (x.x.x.74) ... should i specify the entire Block here like this
ip nat pool TEST x.x.x.74 x.x.x.78 netmask 255.255.255.248?
the Public IP for the web server is x.x.x.76
Just wondering
Hi Michal,
Hope you are doing well,
I have one question from your NAT translation table
When you use Static PAT ,you use
ip nat inside source static tcp (Inside local IP address= Actual device IP) <Local port on which devices are listening> (Inside global IP address = IP which is reachable on internet) <Global UDP/TCP port = Any Random Port>"
following command.
So in your case your statement would be
It mean ur inside local ip is 192.168.1.7 and inside global ip address is x.x.x.76, So when you do sh ip nat translation command it should like this
tcp x.x.x:76      192.168.1.7:443     ---                ---
so first entry will be static entry and then ur dynamic session but your output is showing different 192.168.1.7 address is showing in outside local
I have creted one blog static Pat if want you can go through it.last month i deploy static PAT setup for one customer so it did work fine for them.
One more suggestion if you are using interface to PAT your inside IP address you can direclty Nat on it,you dont need seperate pool for it.Pool is required when you want to do dynamic PAT with multiple IP address
you can use following command:
ip nat inside source list 10 interface gig0/1 overload
Ashish
Dear Ashish
Thanks for the feedback. However, this issue has been sorted out and my routing configuration was fine
All i had to do was to change port number to 8080 and switch to my main IP as the .76 i got was not routable on the internet
John
The config was correct as you mentioned - ISP let me down with a non routable public IP
Hi Mike,
Just change your acl 23 to
access-list 23 deny  host 192.168.1.7
HTH,
Lei Tian
Thanks Lei
I have done that but no luck
Could the error be from this line . . . .
ip nat pool UPMB x.x.x.74 .x.x.x.74 netmask 255.255.255.248?
i was thinking it should be this instead
ip nat pool UPMB x.x.x.74 .x.x.x.78 netmask 255.255.255.248
My Public IP block is from 74 to 78
thanks
Hi Mike,
The 2nd one is correct, but it won't cause the issue that you have. If you change the NAT to
ip nat inside source static tcp 192.168.1.7 x.x.x.76 temporarily, can you ping .76 from internet?
HTH,
Lei Tian
