Errors on Serial interface during E1 BERT test
Felix Troeger
Hi all,
I am currently running a BERT test on an E1 controller. The "show controller e1 bert" command is showing no errors since I started the test (15 minutes ago).
But I found out, that the serial interface associated to that controller is taking massive amounts of errors during the BERT. Here are the current stats:
"7760818 input errors, 464131 CRC, 523691 frame, 1854450 overrun, 0 ignored, 4918547 abort"
There is currently a loop on my circuit which I am testing against. I figured out that the loop is not visibile on the serial during the BERT.
Here are my two questions:
1. Is it normal that the serial interface is taking errors during the BERT, althouth BERT results itself are looking good?
2. Is it a normal behaviour that the loop is not visible on the serial during the BERT?
Would be happy about any help.
Thanks.
Felix Troeger
Just saw it might better fit under "Service Provider - MPLS" or somewhere over there.
Maybe some moderator can move it there.
paolo bevilacqua
You can ignore serial interface statistics during BERT tests.
Well, thanks for clarification.
