STATIC NAT AUTO FAIL OVER TWO DIFFERENT ISPs WITH TWO STATIC VLAN
 sir i have cisco 4300 router.
i want to configure STATIC NAT AUTO FAIL OVER TWO DIFFERENT ISPs WITH TWO STATIC VLAN.
my router interface details: int gig 0/0/0 , 0/0/1, 0/0/2
ISP1
customer WAN ip:162.24.159.241/30
NIB WAN ip (default gateway):172.24.159.242/30
subnet mask:255.255.255.252
LAN IP:117.197.102.217/29
subnet mask 255.255.255.248
ISP2
IP 202.142.74.79
subnet 255.255.255.248
gatway:202.142.74.70
internal VLAN ip
VLAN3 ip: 192.168.6.0/24
VLAN 2 ip: 192.168.7.0/24
drowing attached.
my current configuration with one ISP only.
Building configuration...
Current configuration : 2058 bytes
! Last configuration change at 05:24:30 UTC Thu Apr 28 2022
version 16.6
service password-encryption
no service dhcp
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
subscriber templating
license udi pid ISR4331/K9 sn FDO2444109U
diagnostic bootup level minimal
redundancy
mode none
interface Loopback0
ip address 117.197.102.217 255.255.255.248
ip nat inside
interface GigabitEthernet0/0/0
ip address 192.168.14.1 255.255.255.0
ip nat inside
negotiation auto
interface GigabitEthernet0/0/1
ip address 172.24.159.241 255.255.255.252
ip nat outside
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
negotiation auto
ip nat inside source list 99 interface Loopback0 overload
ip nat inside source list 102 interface Loopback0 overload
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 172.24.159.242
ip route 192.168.14.0 255.255.255.0 172.24.159.242
access-list 99 permit 192.168.14.0 0.0.0.255
control-plane
7 Replies 7
balaji.bandi
adding to other suggestion - check the below thread with IP SLA and failover :
https://community.cisco.com/t5/routing/dual-isp-nat-problem/td-p/818753
BB
--> i want to configure STATIC NAT AUTO FAIL OVER TWO DIFFERENT ISPs WITH TWO STATIC VLAN.
What exactly do you mean by 'with two static Vlan' ? What is a static Vlan ? Can you give an example of what your NAT entries would look like ?
Also, the configuration of the router you have posted does not reflect anything of what you want to accomplish. Does this router support Vlan interfaces ? Is this the router that is supposed to be connected to dual ISPs ?
ISP1
NIB WAN ip (default gateway):172.24.159.242/30 --> is it 172 or 162 ?
LAN IP:117.197.102.217/29 --> which LAN is that ?
ISP2
IP 202.142.74.79
gatway:202.142.74.70 -->  gateway IP address is not in the same subnet
internal VLAN ip
sir this my current configuration. but internet not access from pc 192.168.14.20
ISP1:
CustomerWAN IP : 172.24.159.241/30
NIB WAN IP(Default Gateway):172.24.159.242/30
Subnet Mask: 255.255.255.252
Statis LAN IP: 117.197.102.216/29 to 117.197.202.223/29
Subnet :255.255.255.248
ISP2:
WAN IP: 202.142.74.74 to 78
255.255.255.248
Gateway:202.142.74.73
INTERNAL BRB Network: 192.168.14.1/24
Router>en
Router#sh run
Current configuration : 2909 bytes
! Last configuration change at 13:22:13 UTC Fri Apr 29 2022
version 16.6
hostname Router
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
redundancy
mode none
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
description CONNECTION_TO_BRB_NETWORk
ip nat inside
negotiation auto
description CONNECTION_TO_NISC
ip address 202.142.74.75 255.255.255.248
ip nat outside
negotiation auto
description CONNECTION_TO_BSNL
ip nat outside
negotiation auto
no ip address
negotiation auto
ip nat inside source static 192.168.14.1 172.24.159.242 route-map BSNL_STATIC_NAT
ip nat inside source static 192.168.14.1 202.142.74.73 route-map NISC_STATIC_NAT
ip nat inside source route-map BSNL_NAT interface GigabitEthernet0/0/2 overload
ip nat inside source route-map NISC_NAT interface GigabitEthernet0/0/1 overload
no ip http server
ip route 0.0.0.0 0.0.0.0 202.142.74.73 track 1
ip route 0.0.0.0 0.0.0.0 172.24.159.242 track 2
ip access-list extended INTERNET-ACCESS
permit ip 192.168.14.0 0.0.0.255 any
ip sla 1
icmp-echo 202.142.74.73 source-ip 202.142.74.75
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 172.24.159.242 source-ip 172.24.159.241
ip sla schedule 2 life forever start-time now
route-map NISC_NAT permit 10
match ip address INTERNET-ACCESS
match interface GigabitEthernet0/0/1
route-map BSNL_NAT permit 10
match interface GigabitEthernet0/0/2
route-map BSNL_STATIC_NAT permit 10
route-map NISC_STATIC_NAT permit 10
control-plane
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
event manager applet NISC_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "clear ip nat translation forced"
event manager applet BSNL_DOWN
event track 2 state down
end
Router#
*Apr 29 13:26:58.830: %IP-4-DUPADDR: Duplicate address 202.142.74.73 on GigabitEthernet0/0/1, sourced by 0855.31a5.a046
*Apr 29 13:27:29.002: %IP-4-DUPADDR: Duplicate address 202.142.74.73 on GigabitEthernet0/0/1, sourced by 0855.31a5.a046
*Apr 29 13:27:59.403: %IP-4-DUPADDR: Duplicate address 202.142.74.73 on GigabitEthernet0/0/1, sourced by 0855.31a5.a046
*Apr 29 13:28:30.035: %IP-4-DUPADDR: Duplicate address 202.142.74.73 on GigabitEthernet0/0/1, sourced by 0855.31a5.a046
*Apr 29 13:29:00.196: %IP-4-DUPADDR: Duplicate address 202.142.74.73 on GigabitEthernet0/0/1, sourced by 0855.31a5.a046
*Apr 29 13:29:30.437: %IP-4-DUPADDR: Duplicate address 202.142.74.73 on GigabitEthernet0/0/1, sourced by 0855.31a5.a046
I am not really clear on why you have configured the static NAT entries with the IP addresses of the interface as the source ?
What is the purpose of these entries, what do you want to accomplish ?
ip route 0.0.0.0 0.0.0.0 172.24.159.242 track 2<- remove this track if this will be backup path and config it AD to be 200
Hello
For failover remove the tracking from the secondary default route and add a seed metric higher than 1
no ip route 0.0.0.0 0.0.0.0 172.24.159.242 track 2
ip route 0.0.0.0 0.0.0.0  GigabitEthernet0/0/2 172.24.159.242 5
Kind Regards
Paul
