C93180YC-FX vpc setting
Support ACME
Dear ALL,
I 'm the newbie in Nexus switch, i have 2 x C93180YC-FX for core switch, i had completed the VPC setting, now the switch are still running on independ mode, how to set it up to be one logical switch? It is because i have to run the BGP.
Support
switch 1
# sh run
!Command: show running-config
!Running configuration last done at: Fri Apr 29 16:22:12 2022
!Time: Fri Apr 29 16:27:02 2022
version 9.3(2) Bios:version 05.43
hostname Active
vdc Active id 1
limit-resource vlan minimum 16 maximum 4094
limit-resource vrf minimum 2 maximum 4096
limit-resource port-channel minimum 0 maximum 511
limit-resource u4route-mem minimum 248 maximum 248
limit-resource u6route-mem minimum 96 maximum 96
limit-resource m4route-mem minimum 58 maximum 58
limit-resource m6route-mem minimum 8 maximum 8
cfs eth distribute
feature bgp
feature port-security
feature udld
feature interface-vlan
feature lacp
feature dhcp
feature vpc
feature lldp
no password strength-check
username admin password 5 $5$m9MlJLZi$n.VUtREE0kvUwbxLePH12l6X/KPEfVCgXLdIqjSdFj
1 role network-admin
ip domain-lookup
copp profile strict
snmp-server user admin network-admin auth md5 0x5f7e26d8eccc3ec53bc3667a5a0982ad
priv 0x5f7e26d8eccc3ec53bc3667a5a0982ad localizedkey
rmon event 1 description FATAL(1) owner PMON@FATAL
rmon event 2 description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 description ERROR(3) owner PMON@ERROR
rmon event 4 description WARNING(4) owner PMON@WARNING
rmon event 5 description INFORMATION(5) owner PMON@INFO
vlan 1-2,1400
vlan 2
name keepalive
service dhcp
ip dhcp relay
ipv6 dhcp relay
vrf context keepalive
vrf context management
vpc domain 1
role priority 100
peer-keepalive destination 1.1.1.2 source 1.1.1.1 vrf keepalive
delay restore 150
interface Vlan1
interface port-channel1
switchport
switchport access vlan 1400
speed 1000
interface port-channel100
description *** VPC PEER LINKS ***
switchport
switchport mode trunk
spanning-tree port type network
vpc peer-link
interface Ethernet1/1
switchport
channel-group 100 mode active
no shutdown
interface Ethernet1/2
switchport
no shutdown
interface Ethernet1/3
switchport
speed 1000
channel-group 1 mode active
no shutdown
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
interface Ethernet1/32
interface Ethernet1/33
interface Ethernet1/34
interface Ethernet1/35
interface Ethernet1/36
interface Ethernet1/37
interface Ethernet1/38
interface Ethernet1/39
interface Ethernet1/40
interface Ethernet1/41
interface Ethernet1/42
interface Ethernet1/43
interface Ethernet1/44
interface Ethernet1/45
interface Ethernet1/46
interface Ethernet1/47
interface Ethernet1/48
speed 10000
duplex full
vrf member keepalive
ip address 1.1.1.1/30
no shutdown
interface Ethernet1/49
interface Ethernet1/50
interface Ethernet1/51
interface Ethernet1/52
interface Ethernet1/53
interface Ethernet1/54
interface mgmt0
vrf member management
line console
line vty
boot nxos bootflash:/nxos.9.3.2.bin
router bgp 65532
Active# show vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 0
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Disabled
Delay-restore status : Timer is off.(timeout = 150s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Disabled
Virtual-peerlink mode : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po100 up 1-2,1400
switch 2
Standby# sh run
!Running configuration last done at: Fri Apr 29 15:51:06 2022
!Time: Fri Apr 29 16:31:23 2022
hostname Standby
vdc Standby id 1
cfs eth distribute
feature bgp
feature pim
feature udld
feature netflow
feature hsrp
feature lacp
feature dhcp
feature vpc
feature lldp
username admin password 5 $5$aJmYTHB5$srIPBOrhIRpzBD5LCjqXAnTuvaZV6lxldGCmm5L8uZ
2 role network-admin
ip domain-lookup
copp profile strict
snmp-server user admin network-admin auth md5 0xbe686049cb8c117cac0653d6e0aab8c5
priv 0xbe686049cb8c117cac0653d6e0aab8c5 localizedkey
vlan 1-2,1400
vlan 2
name keepalive
service dhcp
ip dhcp relay
ipv6 dhcp relay
vpc domain 1
role priority 150
peer-keepalive destination 1.1.1.1 source 1.1.1.2 vrf keepalive
delay restore 150
interface Vlan1
interface Vlan1400
ip address 10.194.0.2/24
switchport
speed 1000
vpc 1
switchport
vpc peer-link
switchport
no shutdown
switchport
no shutdown
switchport
speed 1000
no shutdown
speed 10000
duplex full
ip address 1.1.1.2/30
no shutdown
interface mgmt0
line console
line vty
Standby# show vpc
Legend:
vPC domain id : 1
vPC role : secondary
Number of vPCs configured : 1
1 Po100 up 1-2,1400
vPC status
Id Port Status Consistency Reason Active vlans
1 Po1 down* failed Peer does not have -
corresponding vPC
Please check "show vpc consistency-parameters vpc <vpc-num>" for the
consistency reason of down vpc and for type-2 consistency reasons for
any vpc.
Standby#
2 Accepted Solutions
You must config VPC number under ether channel connect to third SW to make vPC work otherwise the vPC never work.
first SW
switchport
speed 1000
vpc 1 <- missing
second SW
switchport
speed 1000
vpc 1
Support ACME
Dear Sir,
Is it impossible like one logical switch to manage the switch?
Support
