Static NAT configuration on Router with WAN interface configured as Dial-UP
We have a site were Router WAN interface is configured with PPPoe - dial up. There is a requirement of publishing one application outside from same site. Is there any option to configured source static NAT pointing to dial-up WAN interface.
balaji.bandi
its possible with some challenges.
how will outside internet device and reach internally (since you have dynamic IP address)
in this case you need to use dynadns with EEM Script to update the IP address information. so you can allow the users can access internal resources.
1. Dyna DNS
2. EEM Script to update the IP.
3. Static NAT
4. ACL.
BB
Thanks for the information,
Can you share any link for dynadns with EEM Script configuration.
here is the example configure with Dynamic DNS
https://www.noip.com/support/knowledgebase/using-your-cisco-router-with-no-ip-dynamic-dns-services/
you need to setup static  NAT for inbound using interface - it should work as expected. test and advise.
BB
Thanks for the details, will test on this.
