Static NAT exclusions via route map not working.
Wan_Whisperer
Okay,
I have googled and I can't seem to understand why "ALL" my static NATs are excluded and they are failing over to NAT Overload.
NAT
So I have a private network 172.19.150.0/24 that is NAT overload but some are static inside that network.  I need to exclude all static NAT to some networks.  I am 90% it because of my Route Map.
What is happening is when I apply the Route map to the static NAT it is excluding the NAT to all netowrks and not the ones in my ACL and then hitting my NAT overload.  I think its my Route map because when I remove the route map on the static NAT the 1 to 1 NAT works and when I add the Route map the statics don't work to any network and they Nat to my overload IP address.
See configs below:
ip nat pool Pool1 191.XXX.XXX.1 191.XXX.XXX.1 netmask 255.255.255.0
ip nat inside source static 172.19.150.125 191.XXX.XXX.49 route-map Static_Nat_RM redundancy 1 mapping-id 6
ip nat inside source static 172.19.150.190 191.XXX.XXX.93 route-map Static_Nat_RM redundancy 1 mapping-id 15
ip nat inside source list NATSource pool Pool1 redundancy 1 mapping-id 1 overload
route-map Static_Nat_RM permit 10
match ip address Static_Nat_ACL
ip access-list extended Static_Nat_ACL
deny ip host 172.19.150.190 103.XXX.XXX.0 0.0.3.255
permit ip 172.19.150.0 0.0.0.255 any
ip access-list extended NATSource
When I am on 172.19.150.190 and I ping 8.8.8.8 I can see:
172.19.150.190 translating to 191.XXX.XXX.1
When I am on 172.19.150.190 and I ping 103.XXX.XXX.0 I can see:
When I ping 8.8.8.8 from 172.19.150.190 I want it to translate to 191.XXX.XXX.93 but its not.
If I remove my Route map from the static nat:
BEFORE:
AFTER:
ip nat inside source static 172.19.150.190 191.XXX.XXX.93  redundancy 1 mapping-id 15
and I get on 172.19.150.190 and I ping 8.8.8.8 I can see:
172.19.150.190 translating to 191.XXX.XXX.93
Sooo.  It seems like something is wrong with my router map because I add it and noting is 1 to 1 natted at all...It just catches the NAT overload.
****edit***
Is it possible that it hitting the Overload NAT before it hits the static NAT?
Is my Route Map written incorrectly?  (PS I see no hits on my ACL under the route map
18 Replies 18
Jaderson Pessoa
@Wan_Whisperer Hello,
route-map Static_Nat_RM permit 10    << this policy is applied on which interface?  post here service policy
Jaderson Pessoa
*** Rate All Helpful Responses ***
Wan_Whisperer
Everyones reply got me thinking about order of operation and I figured it out!
For some reason when I add the route map to the one to one nat it hits the NAT overload first.  Once I exclude the one to one from the NAT Overload it hits the One to One then hits the routemap!
So it works!
Sorry, I am not following.
How do you exclude the one to one NAT from the NAT overload ?
Jon
Hello Wan,
Can you give a configuration example from what you figured out?  I still have the same issue
Thanks for your time
