STATIC NAT Problem on IOS 15.x
CCertified85
Few are the issues that I am facing on IOS Version 15 and Cisco 1941 Router , this router is currently in production on clients.
  • •1.       I do PAT on router interface , and it has public IP on it , when I send request to Internet via Browser from LAN client , Page does not open and when I check  NAT TRANSLATION on router , Router does translate the packets. The work around I found is that when I disabled CEF on router , Web starts browsing ,  Why does this happen and why I need to disable CEF ?
  • •2.       I have Public IP Pool its subnet mask is /29 , one of the Public IP from this pool is live on the interface. When I perform STATIC NAT a web server resides in LAN , then I can access this server from anywhere in the world by IP.
After few days Static NAT stopped working , I again Static NAT it on other Public IP , the same issue rise again , I am not able to access this server from Internet. This issue has been faced at two clients.   The same pool i have checked on 1841 router and static nat works fine on the same public IP .
I have upgraded the IOS as well to version 15.1 but  STATIC NAT issue is not solved.
Please Help me out in this regard.
I would be grateful
anthony.kellar
Gonna have to post a config on this one...
Sorry its confidential ... I cant share ...
If you want to ask related questions u can...
Normal default routes are there in router pointing to ISP.
Normal Static NAT commands are there , nothing complex
