static route leaking ... Is there a similar command to JUNOS "next-table"
Dears
Would like your assistance please regarding below
Is there a similar command to JUNOS "next-table" in Cisco ?
Would like to do MPLS VPN route leaking between 2 vrfs. route-targets can not be used as I am only receiving default route so leaking default route is never a good idea. Problem I can't use static route as there is no next-hop/interface being an MPLS network
What I wish is to define specific static routes and tell router to search in a different VRF for the next-hop/interface.
From what I can see is that leaking with static route can only be done by specifying an interface that is in a different vrf
;i.e  ip route vrf blue x.x.x.x 255.255.255.255 fa0/1 10.0.0.0.2
interface fa0/1
 ip vrf forwarding green
 ip address 10.0.0.1 255.255.255.0
What I wish to do
ip route vrf blue x.x.x.x/24 next-table orange
Any ideas ?
6 Replies 6
Any ideas ?
Hi sherifismail,
I haven't understand why you can't use a static route specifying an interface of the second VRF. Could you explane little more ?
Enrico
Hello
You can trying using a static to Null 0 and advertise it and then use RT's to import it.
Ip route x.x.x.x y.y.y.y. null 0
res
Paul
Kind Regards
Paul
Dears
Thanks for your reply/assistance
@ Enrico
Unfortunately I can't use this as next-hop interface is the MPLS interface so actually no next-hop IP
@ Paul
This would be possible from remote side. Bad news I have no access to it
I did a workaround for this issue but its not the best solution.
Sherif Ismail
As far as I know you can make the config suggest by Paul on your router, MP-BGP can import between VRFs on the same router, no need  to configure the static route on a remote router. Am I wrong ?
E
Dear Ciollaro
Lets say I am having 2 VRFs on router R1 ; vrf orange and vrf green.
vrf orange is importing RT 1:1 from MP-BGP/MPLS  that includes among many prefix 10.0.0.0/24 .
Now there are users in vrf green who want to access servers within same prefix however restriction that you should not do use import/export nor do changes in remote side thats why I was thinking of Juniper command "next-table"
Sherif Ismail
