Static route with same target network but different next hops
Blvesteel
Good day,
I am trying to use Static route for 2 separate network with the same subnet (see attached image). However when i applied the config(see below), the ping from pc to the center router is inconsistent. I know the router is confused and tries to deliver the traffic to both the next hops indicated. How can i have 100 percent ping with just
-static route
-def route going to center router
-not changing the LAN IP
And just in case, does the solution involves the right type of static-recursive, direct, fully specified?
The config is below,
//////////////////////////////R2/////////////////////////////
interface FastEthernet0/0
description Gateway of LAN
ip address 10.1.1.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
description Link to R1(center router)
ip address 192.168.1.2 255.255.255.0
interface Serial3/0
no ip address
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip flow-export version 9
////////////////////////////////R1/////////////////////////
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
description link to R2(left router)
clock rate 2000000
interface Serial3/0
description link to R3(right router)
ip address 192.168.2.1 255.255.255.0
clock rate 2000000
no ip address
shutdown
no ip address
shutdown
ip classless
ip route 10.1.1.0 255.255.255.0 192.168.1.2
ip route 10.1.1.0 255.255.255.0 192.168.2.2
//////////////////////////////////R3/////////////////////////////////////////
description gateway of LAN
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial3/0
ip address 192.168.2.2 255.255.255.0
no ip address
shutdown
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.1
Thank you in advanced
Hello
instructed by whom?
The way your topology is setup default static routing won’t work unless the person who has instructed you means to  apply static routes just for eachend host and not the subnet if that’s the case then it would work
The host routes would be like-
ip route 10.0.0.10 255.255.255.255 192.168.1.1
Ip route 10.0.0.20 255.255.255.255 192.168.2.1
Kind Regards
Paul
12 Replies 12
a.alekseev
Level 7
Level 7
create host static route
Hi, both the hosts have same IP
What are you trying to do?
Actually this is just a part of a bigger network, however i am having trouble regarding this problem. Also, i am not allowed to add nat or dynamic routing protocol to the network. Just static
you can create NAT instead the Static Route on R1
Hi yeharold, if i can only use NAT, it would work but i am strictly instructed to just use static route
Hello
you have a network which is discontinuous (10.0.0.0/24) separated by a transit router
So unless you apply some nat translation you will still experience your issue with the two default statics unless you reconfigure one side with a different network range
Kind Regards
Paul
Thanks Paul, but i am instructed to just only use static route.
Hello
instructed by whom?
Kind Regards
Paul
I also would like to know who instructed you on this and like to know what they are trying to accomplish. If we look carefully at the diagram it really is more than discontiguous network. Both hosts in the diagram have exactly the same IP address of 10.1.1.100. You can not have two hosts in two different parts of the network use exactly the same IP address. What appears to be in the instructions can not be accomplished - not even with nat or anything like that.
Rick
Rick
Noted sir. Thanks for the advice sir richard, i guess i would just apply the solution suggested by paul. Maybe rhat would work
Thank you, maybe that will do. initially, the users on both network have rhe same ip. It is like, they are exactly the same network connected to a router using static route. But maybe i could change the host ip and apply the static route. Thank you very muchhhhhhh.👏👏👏👏👏
