Static Route
vishwancc
Level 3
Level 3
Hi ALL:
I have 2 links primary is MPLS if MPLS goes down IPSEC is established using other link
Whats happenning is 1 of the static route enrty is showing when the IPSEC is down and when i am trying to remove it it giving error.
I am using 7206xm.
MPLSR1#sh ip route static | i 10.20.28.0
S 10.20.28.0/24 [1/0] via 10.252.19.23
MPLSR1#sh crypto isakmp sa | i 10.252.19.23
MPLSR1#sh ip route 10.20.28.1
Routing entry for 10.20.28.0/24
Known via "static", distance 1, metric 0
Redistributing via eigrp 100
Advertised by eigrp 100 metric 10000 100 255 1 1500
Routing Descriptor Blocks:
* 10.252.19.23
Route metric is 0, traffic share count is 1
HBBCPMPLSR1#sh ip route static | i 10.20.28.0
HBBCPMPLSR1(config)#no ip route 10.20.28.0 255.255.255.0 10.252.19.23
%No matching route to delete
Chao
Vishwa
Yasir Ashfaque
on HBB type "show run | i ip route"
and see what exact command have you added and then do no to that.. or try to reload
Hi ,
Sorry my bad its all the output are from MPLSR1 ,please ignore HBB at front.
Chao
Vishwa
