static route
adnan.dhl
How to configure two static routes for the same network but different ports one for ethernet and other for the BRI on the same router?
Danilo Dy
Without knowing the relationship between the two interface, its difficult to guess.
However, if they are configured as primary/backup. Try floating static route http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a0080093f7e.shtml
Dandy
shivlu jain
Level 5
Level 5
you can do like the given
ip route 10.0.0.0 255.0.0.0 fasetethernet0/0
ip route 10.0.0.0 255.0.0.0 fasetethernet0/1 60
60 is the preference, as you are increasing the pref the route will be less prefered.So it will be your secondary route.
regards
shivlu
HI,
If it is the floating static routes use can use the increased AD as 200 for secondary Link.
ip route 10.0.0.0 255.0.0.0 fasetethernet0/1 200
Pls Rate all Informative Post
Best Regards,
Guru Prasad R
On a MEN, having a floating static route can give issues.
MEN connects to the router through a switch which in turn connects to the providers network through fiber. If there is a fiber cut at the provider's end, the connectivity between the router and the provider switch will still be UP and the routing entry for 10.0.0.0 will still be reachable through f0/0
Traffic will never fall back on f0/1
-Sai.
