static routing configured, not able to ping
anandu1797
Hey guys, I have a current setup as shown in the screenshot, my aim is to ping to the other device and I configured static route for the routers but I am not able to ping. Can anyone suggest what to be done by seeing the screenshots?
10 Replies 10
Jon Marshall
On the router on the left in your diagram -
ip route 192.168.200.0 255.255.255.0 10.1.1.x (the 10.1.1.x IP is the router on the right).
On the router on the right -
ip route 192.168.100.0 255.255.255.0 10.1.1.x (the 10.1.1.x IP is the router on the left)
Jon
I have already executed those commands and not able to ping
Not according to the outputs you posted.
Can you post the configurations of both routers.
Jon
find the screenshots below
post the zipped Packet Tracer project (.pkt) file...
tommus719
probably you just forgot to enter the default gateway on the PCs config tab
Gateways were already added
tommus719
post your PT file
Please check this out
Hey guys, I figured it out. The gateway for PC and IP address for interface connected to PC were different. I made it same and now I am able to ping
