static routing not working
carlbert1999
Hi, I'm a newbie in networking. I set up static routing correctly according to my CCNA course, but when I test it, it's not working—even though it's very simple. Can anyone please help me? Thank you!
3 Accepted Solutions
Chaminda1912
@carlbert1999 could you paste the configuration and  highlight the connectivity ..I cannot open your zip file unfortunately due to my FW settings
the problem is that the interfaces connecting both of your routers are not in the same subnet. Make the changes marked in bold:
Router0
interface GigabitEthernet0/0
ip address 192.168.3.2 255.255.255.0
Router1
Router(config)#no ip route 192.168.1.0 255.255.255.0 192.168.2.1
Router(config)#ip route 192.168.1.0 255.255.255.0 192.168.3.2
Attached the revised, working file.
Blue_Bird
Hello carlbert1999,
Bother router's (Router0 and Router1) Gig0/0 interfaces must be in the same network.
Based on that you will be needed modify the configurations...
Perfrom the following steps:
Router1(config)# interface Gig0/0
Router1(config-if)# no ip address
Router1(config-if)# ip address 192.168.2.2 255.255.255.0
Router1(config-if)# no shutdown
Rotuer0(config)# no  ip route 192.168.4.0 255.255.255.0 192.168.3.1
Rotuer0(config)#  ip route 192.168.4.0 255.255.255.0 192.168.2.2
Now, ping from pc to pc..it works..!
Best regards
******* If This Helps, Please Rate ********
5 Replies 5
Chaminda1912
Router0
Router1
Thank you, sir. My understanding was that I thought I could connect it using a different network address.
Blue_Bird
Hello carlbert1999,
Best regards
carlbert1999
Thank you, sir. Now it's working.
