Troubleshooting IPv6 addressing and IPv6 DHCP
Andrew guory009
I'm working on a course assignment, but I have encountered some obstacles and hope to get some suggestions or guiding solutions.
I tried some repair measures. The only successful repair measure was to enable SLAAC successfully, so that the PC could ping the entire network. However, I didn't record the process, which made me unable to reproduce it. And when I was able to ping successfully, I also realized that the PC did not receive the "reply" from the DHCP server.
In addition to the solutions and suggestions, I also hope to know how you investigate or use the empirical skills, as well as the principles involved behind this problem. I want to know more so that I can solve or identify similar problems by myself next time.
R1
Building configuration...
Current configuration : 2404 bytes
! Last configuration change at 14:40:48 UTC Thu Mar 13 2025
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname R1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 $1$eec1$Z7PaL1EXqO148wLnAi9y20
no aaa new-model
login on-success log
subscriber templating
vtp domain MawsonLakes
vtp mode transparent
ipv6 unicast-routing
license udi pid ISR4331/K9 sn FDO24160K4L
license accept end user agreement
license boot suite FoundationSuiteK9
no license smart enable
diagnostic bootup level minimal
username admin privilege 15 secret 9 $9$wXsizaeNVwl02A$aikqw3ye3uYI6AQGLZ6LZfi8tSdvuTA8QeJGQF7Hc7A
redundancy
 mode none
interface Loopback0
 ip address 209.165.200.225 255.255.255.248
 ipv6 address FE80::1:3 link-local
 ipv6 address 2001:DB8:A:C::1/64
interface GigabitEthernet0/0/0
 ip address 10.10.20.1 255.255.255.0
 negotiation auto
 ipv6 address FE80::1:1 link-local
 ipv6 address 2001:DB8:A:B::1/64
interface GigabitEthernet0/0/1
 ip address 10.10.10.1 255.255.255.0
 ip helper-address 10.10.20.254
 negotiation auto
 ipv6 address FE80::1:2 link-local
 ipv6 address 2001:DB8:A:A::1/64
 ipv6 address 2001:DB8:A:A::/64 eui-64
 ipv6 dhcp relay destination 2001:DB8:A:B::2
interface GigabitEthernet0/0/2
 no ip address
 negotiation auto
interface Serial0/1/0
 no ip address
interface Serial0/1/1
 no ip address
interface Serial0/2/0
 no ip address
interface Serial0/2/1
 no ip address
 vrf forwarding Mgmt-intf
 no ip address
 negotiation auto
ip forward-protocol nd
no ip http server
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 Loopback0
ipv6 route ::/0 Loopback0
control-plane
banner motd ^C This is R1, Trouble Ticket 1.1.2.3 ^C
alias exec reset.now tclsh flash:/enarsi/reset.tcl
line con 0
 exec-timeout 0 0
 logging synchronous
 transport input none
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login local
 transport input telnet
end
R2
Current configuration : 2276 bytes
! Last configuration change at 07:38:20 UTC Thu May 9 2024
version 16.9
hostname R2
boot-start-marker
boot-end-marker
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 $1$R0uh$pGx83hV/5il6QXCOQCOQS1
no aaa new-model
ip dhcp excluded-address 10.10.10.1 10.10.10.100
ip dhcp pool LAN4_10
 network 10.10.10.0 255.255.255.0
 default-router 10.10.10.1
 domain-name ccnp4lab.com
 dns-server 10.10.20.1
vtp domain merger.com.au
ipv6 dhcp pool LAN6_A
 dns-server 2001:DB8:A:B::1
 dns-server 2001:DB8:A:B::2
 domain-name ccnp6lab.om
license udi pid ISR4331/K9 sn FDO24160K04
username admin privilege 15 secret 9 $9$soAi7yMBgrvzeD$iR3q1zjeVVvOBRmdVp3dlSaULGVyQARKZgdU/3buCOA
redundancy
 mode none
 ip address 10.10.20.254 255.255.255.0
 negotiation auto
 ipv6 address FE80::2:1 link-local
 ipv6 address 2001:DB8:A:B::2/64
 ipv6 dhcp server LAN6_A
 no ip address
 negotiation auto
 no ip address
 negotiation auto
 no ip address
 no ip address
 no ip address
 negotiation auto
no ip http server
ip route 0.0.0.0 0.0.0.0 10.10.20.1
ipv6 route ::/0 2001:DB8:A:B::1
control-plane
banner motd ^C This is R2, Trouble Ticket 1.1.2.3 ^C
line con 0
 exec-timeout 0 0
 logging synchronous
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login local
end
D1
Current configuration : 9617 bytes
! Last configuration change at 14:37:53 UTC Thu Mar 13 2025
version 16.9
no service pad
! Call-home is enabled by Smart-Licensing.
service call-home
hostname D1
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 $1$Cb2l$mnnbxxcsnGW4H2xKDQiQf/
no aaa new-model
switch 1 provision ws-c3650-24ps
call-home
 ! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
 ! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
 contact-email-addr sch-smart-licensing@cisco.com
 profile "CiscoTAC-1"
  active
  destination transport-method http
  no destination transport-method email
crypto pki trustpoint TP-self-signed-2750515143
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2750515143
 revocation-check none
 rsakeypair TP-self-signed-2750515143
crypto pki trustpoint SLA-TrustPoint
 enrollment pkcs12
 revocation-check crl
crypto pki certificate chain TP-self-signed-2750515143
 certificate self-signed 01
  30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32373530 35313531 3433301E 170D3235 30333133 31343333
  35385A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37353035
  31353134 33308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
  0A028201 0100B2DE D80C1DED 9B2CD865 0A96981C 35BF085D 3141B2C8 FD5BB390
  B7727D60 78D59B03 5395651F 72EF0914 F4BE8E0F C011A352 88CC4EED ED1DF950
  FD2709DF 68D5D269 7047DC81 F6E1799A BC105C54 53EE5AF3 C3935B90 2EEBF0BE
  D332C918 D355DB84 34180E0B 7E3C261A 766AC369 7316EC55 6ECD2DD6 D6E87880
  892C9C22 A88CFCD7 0D3250A3 CC27541C F8C8BDF2 3D62B817 B5BBEA09 0745E36E
  F2A795A2 95690804 633B8E81 24DC1B1E BC455546 472ED2A7 23056F0E 7A00AF77
  0662C265 29C7EB7C BA50689B BEEFDF41 F7F84DC9 B55438A2 A99D60AF B4EDCC86
  D2A7B049 43BB12BB 0389D089 C556BD49 29CE0DE6 E3568DF7 60A75C37 A799086D
  89899939 3C830203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
  301F0603 551D2304 18301680 148D8DA0 9D03EAD6 013E5085 AC514F11 0D578D5B
  C3301D06 03551D0E 04160414 8D8DA09D 03EAD601 3E5085AC 514F110D 578D5BC3
  300D0609 2A864886 F70D0101 05050003 82010100 2FD134CD 5C9D0D4C 4D122CF6
  BE6FD6F0 7E85F678 F734D02D 06D503BD C8EA847F D8497A2F 6B7D2E1D 049C9686
  9314F65D 663E0891 1CB02DC2 9C5648A2 BD504F22 E953DF4C 805CEE9A 9572B754
  99174C54 A3EDFAAE 12FA79D6 EEDFCAA8 123617EE BCEA7A1D 2F2DA151 81DE5390
  58BE4DEE DB236646 43FAF300 3535EF23 287E4DF2 753B64B6 CB996A1D 838A2E2F
  D035F1E3 907C0C82 D7F62005 DAF15F87 7A237C7A E9A068CD 620DFCF7 873AC14E
  62BDE81B D73AF1BA 1375C525 E8E08596 6B46AB53 69D791A8 6348AB15 190CA5FD
  99013901 8AC49EF3 C6CD8DCE A42E03FA 8C576B0F 7A51E99E 1844A78E 85387D4E
  32073621 F37C2CEA 568C0B1D 67B237B2 33A9B016
        quit
crypto pki certificate chain SLA-TrustPoint
 certificate ca 01
  30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
  32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363
  6F204C69 63656E73 696E6720 526F6F74 20434130 1E170D31 33303533 30313934
  3834375A 170D3338 30353330 31393438 34375A30 32310E30 0C060355 040A1305
  43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720
  526F6F74 20434130 82012230 0D06092A 864886F7 0D010101 05000382 010F0030
  82010A02 82010100 A6BCBD96 131E05F7 145EA72C 2CD686E6 17222EA1 F1EFF64D
  CBB4C798 212AA147 C655D8D7 9471380D 8711441E 1AAF071A 9CAE6388 8A38E520
  1C394D78 462EF239 C659F715 B98C0A59 5BBB5CBD 0CFEBEA3 700A8BF7 D8F256EE
  4AA4E80D DB6FD1C9 60B1FD18 FFC69C96 6FA68957 A2617DE7 104FDC5F EA2956AC
  7390A3EB 2B5436AD C847A2C5 DAB553EB 69A9A535 58E9F3E3 C0BD23CF 58BD7188
  68E69491 20F320E7 948E71D7 AE3BCC84 F10684C7 4BC8E00F 539BA42B 42C68BB7
  C7479096 B4CB2D62 EA2F505D C7B062A4 6811D95B E8250FC4 5D5D5FB8 8F27D191
  C55F0D76 61F9A4CD 3D992327 A8BB03BD 4E6D7069 7CBADF8B DF5F4368 95135E44
  DFC7C6CF 04DD7FD1 02030100 01A34230 40300E06 03551D0F 0101FF04 04030201
  06300F06 03551D13 0101FF04 05300301 01FF301D 0603551D 0E041604 1449DC85
  4B3D31E5 1B3E6A17 606AF333 3D3B4C73 E8300D06 092A8648 86F70D01 010B0500
  03820101 00507F24 D3932A66 86025D9F E838AE5C 6D4DF6B0 49631C78 240DA905
  604EDCDE FF4FED2B 77FC460E CD636FDB DD44681E 3A5673AB 9093D3B1 6C9E3D8B
  D98987BF E40CBD9E 1AECA0C2 2189BB5C 8FA85686 CD98B646 5575B146 8DFC66A8
  467A3DF4 4D565700 6ADF0F0D CF835015 3C04FF7C 21E878AC 11BA9CD2 55A9232C
  7CA7B7E6 C1AF74F6 152E99B7 B1FCF9BB E973DE7F 5BDDEB86 C71E3B49 1765308B
  5FB0DA06 B92AFE7F 494E8A9E 07B85737 F3A58BE1 1A48A229 C37C1E69 39F08678
  80DDCD16 D6BACECA EEBC7CF9 8428787B 35202CDC 60E4616A B623CDBD 230E3AFB
  418616A9 4093E049 4D10AB75 27E86F73 932E35B5 8862FDAE 0275156F 719BB2F0
  D697DF7F 28
        quit
license boot level ipservicesk9
spanning-tree mode rapid-pvst
username admin privilege 15 secret 9 $9$tctNtMMrii/NIE$7Kxy0LFOi0qfUpfYRy5ARsmFq8vvdLvkQKyCz/zPEMs
redundancy
 mode sso
transceiver type all
 monitoring
class-map match-any system-cpp-police-topology-control
  description Topology control
class-map match-any system-cpp-police-sw-forward
  description Sw forwarding, L2 LVX data, LOGGING
class-map match-any system-cpp-default
  description Inter FED, EWLC control, EWLC data
class-map match-any system-cpp-police-sys-data
  description Learning cache ovfl, High Rate App, Exception, EGR Exception, NFL SAMPLED DATA, RPF Failed
class-map match-any system-cpp-police-punt-webauth
  description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
  description L2 LVX control packets
class-map match-any system-cpp-police-forus
  description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
  description MCAST END STATION
  description Transit Traffic and MCAST Data
class-map match-any system-cpp-police-l2-control
  description L2 control
class-map match-any system-cpp-police-dot1x-auth
  description DOT1X Auth
class-map match-any system-cpp-police-data
  description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
  description Stackwise Virtual
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
  description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
  description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
  description DHCP snooping
class-map match-any system-cpp-police-system-critical
  description System Critical and Gold Pkt
policy-map system-cpp-policy
 vrf forwarding Mgmt-vrf
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet1/0/1
 switchport mode access
 shutdown
interface GigabitEthernet1/0/2
 shutdown
interface GigabitEthernet1/0/3
 shutdown
interface GigabitEthernet1/0/4
 shutdown
interface GigabitEthernet1/0/5
 shutdown
interface GigabitEthernet1/0/6
 shutdown
interface GigabitEthernet1/0/7
 shutdown
interface GigabitEthernet1/0/8
 shutdown
interface GigabitEthernet1/0/9
 shutdown
interface GigabitEthernet1/0/10
 shutdown
interface GigabitEthernet1/0/11
 switchport access vlan 10
interface GigabitEthernet1/0/12
 shutdown
interface GigabitEthernet1/0/13
 shutdown
interface GigabitEthernet1/0/14
 shutdown
interface GigabitEthernet1/0/15
 shutdown
interface GigabitEthernet1/0/16
 shutdown
interface GigabitEthernet1/0/17
 shutdown
interface GigabitEthernet1/0/18
 shutdown
interface GigabitEthernet1/0/19
 shutdown
interface GigabitEthernet1/0/20
 shutdown
interface GigabitEthernet1/0/21
 shutdown
interface GigabitEthernet1/0/22
 shutdown
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip address 10.10.10.2 255.255.255.0
ip default-gateway 10.10.10.1
ip http server
ip http authentication local
control-plane
 service-policy input system-cpp-policy
banner motd ^C This is D1, Trouble Ticket 1.1.2.3 ^C
line con 0
 exec-timeout 0 0
 logging synchronous
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login
line vty 5 15
 login
end
Andrewguory009_0-1741878314274.pngAndrewguory009_1-1741878324914.pngAndrewguory009_2-1741878337088.png
@balaji.bandi Thanks you for your help, if you want to and have free time, you are welcome to answering!
balaji.bandi
start with below guide : (if you learning then suggest to post in learning cisco community is best place to learn)
https://study-ccna.com/how-to-configure-ipv6/
BB
Thank you for guiding the standardized posting. I will take this as a template and premise to integrate into the community.How to Ask The Cisco Community for Help
I don't quite understand what you said about this "learning cisco community". Is it that posts are labeled with this tag or there is a community with this name. I haven't found what you mentioned. Could you give a URL?
Harold Ritter
Hi @Andrew guory009 ,
You need to check the routing between R1 and R2. This should be fairly easy, as you have one static route per router. Make sure the static routes are correct and this should solve this specific issue.
Harold
at first glance, I agree with @Harold Ritter , your IPv6 routing does not look right. On R1, your IPv6 default route points to a local Loopback interface. What if you change that:
to:
ipv6 route ::/0 2001:DB8:A:B::2
