Static routing on home lab - Beginner help
The51stAgent
Greetings,
Please forgive my absolute ignorance on the subject, as I am just starting out with my recently-bought home lab.
I have 3 routers (Cisco 1841s) and I am trying to connect them together and send a ping when consoled into router 1. I configured each of the IPs/subnets as per the instructions in this lesson I am following for static routing. As of now, I cannot get a response and I don't understand why. I am trying to ping 192.168.1.2 from Router 1 and get no reply.I am using a crossover cable to connect port fa0/0 of R1 to fa0/0 of Router 2 and another crossover cable from fa0/1 on R2 to fa0/0 of R3.
I have noticed that when I have been configuring the interface and IP for each router and fast ethernet port on it, that after I do the "no shut" command, I get a message that "Line protocol on interface FastEthernet0/0 changes state to up." that is then followed automatically by "Line protocol on interface FastEthernet0/0 changes state to down." and I have no idea why this is. I am also noticing that the ports that my crossover cables are plugged into are not lit up on any of the routers.
cisco_lab.jpgHere are the show run info for each of the 3 routers:
R1:
duplex auto
speed auto
random-detect
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
interface Serial0/1/0
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
____________________________________________
R2:
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
no ip address
shutdown
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
________________________________________________________
R3:
ip address 192.168.2.3 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
no ip address
shutdown
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
end
Seb Rupik
Hi there,
Can you share the output of sh int fa0/0
There is a chance the interface may be faulty, have you tried moving the config to fa0/1 and connecting to that? You will need to:
conf t
default int fa0/0
exit
There is also a good chance the cross-over cable has been badly crimped. Do you have another one you could try?
cheers,
Seb.
7 Replies 7
Seb Rupik
Hi there,
conf t
default int fa0/0
exit
cheers,
Seb.
Thank you guys for your help so far. The ports are definitely good as they light up when my laptop with the straight cable is plugged into any of them. I'm sure the crossover cables are fine as well.This is what it shows for sh interface for each of my routers:
R1:
Router#sh int fa0/0
FastEthernet0/0 is administratively down, line protocol is down
Hardware is Gt96k FE, address is 40f4.ec7c.f9d2 (bia 40f4.ec7c.f9d2)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto Speed, 100BaseTX/FX
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes
Received 0 broadcasts (0 IP multicasts)
0 watchdog
0 packets output, 0 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier
_________________________________________________________________
R2 Router#sh int fa0/0
Hardware is Gt96k FE, address is e804.62de.bfea (bia e804.62de.bfea)
0 watchdog
______________________________________________________________________
R3
Router>sh int fa0/0
Hardware is Gt96k FE, address is 68bd.ab7b.ffba (bia 68bd.ab7b.ffba)
0 watchdog
Hi there,
Looking at your sh int output, all of the interfaces in an admin-down state. As @Deepak Kumar  pointed out earlier, for each of the interface you are using, issue the no shut command, eg:
!! R1
int fa0/0
  no shut
Do this on every interface along the path between R1 and R3.
cheers,
Seb.
Thank you, Seb. I think I finally figured out the problem. So every single time I would do the no shut command, it would ALWAYS spit out a "changed state to up" line follow immediately by a "changed state to down" line no matter what I tried. Finally, I swapped my crossover cable for a different one included in my kit and now the ports light up as they should and I can ping R2 from R1, etc. Some cables that were including in my kit were labeled "T1 crossover cables" and those were the ones I was originally using. Other cables, upon closer examination were labeled "Cat 5E crossover patch cable". After using the latter, things seem to be working now. I guess the T1 crossover cables are only to be used in the T1 DSU/CSU ports in my routers and that's why it didn't work? Still kind of confusing to me, but I appear to be able to move along now. I really appreciate your help.
Hi there,
T1 and Ethernet crossover cables are wildly different and as such use different pairs to operate. Check the pin outs of both cables side by side, better still google the wiring diagrams of both types.
cheers,
Seb.
on a side note, there used to be the interface command 'loopback' which was sort of an internal self test. If you configure that on the interface, the interface should go to up/up if it is not faulty...
You could also just connect a straight cable to the ports with a PC attached in order to at least verify that the ports work.
Deepak Kumar
Make some changes as below:
R1:
ip route 192.168.2.0 255.255.255.0 192.168.1.2
R2:
ip add 192.168.2.2 255.255.255.0
no shutdown
R3:
ip route 192.168.1.0 255.255.255.0 192.168.2.2
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
