Static routing with OSPF
punasup
Here's a my topology:
As you can see, R1, R2, R3 and R4 are configured with OSPF (all the networks connected are declared). My goal is to configure R5 only with sating routing to better understand how it works.
So I configured all the static routes on R5, for example:
ip route 10.8.0.0 255.255.255.252 10.8.1.21
ip route 10.8.0.4 255.255.255.252 10.8.1.21
ip route 10.8.0.12 255.255.255.252 10.8.1.21
ip route 10.8.0.16 255.255.255.252 10.8.1.21
ip route 192.168.1.0 255.255.255.0 10.8.1.21
I'm a bit confused about the others routers, shoul I add the network 192.168.2.0/24 with a static route on all routers ?
Thanks!
2 Accepted Solutions
on R3, you could add:
ip route 0.0.0.0 0.0.0.0 ethernet1/2 or IP address
router ospf 1
default-information originate
This would send a default route to all other OSPF routers, hence making it unnecessary to add static routes on all other routers...
Hello
@Georg Pauwen on R3, you could add:
!router ospf 1
@MHM Cisco World simple solution
config static route in R3 and redistribute this static route into ospf.
Adding a default static route on R3 pointing towards rR5 would only be applicable if you want all default traffic from R3 to route towards R5 however then to redistribute a default route to R5 would then cause a routing loop, so you DONT want to do this.
Plus performing the above would also advertise a default route to ALL other ospf rtrs in that topology which im sure you dont want to do either.
As you mention static routing then the easiest solution would be to manually add a default static route on R5 pointing towards R3.
R5
ip route 0.0.0.0 0.0.0.0 eth1/0 10.8.1.23
Kind Regards
Paul
5 Replies 5
simple solution
balaji.bandi
As suggested - on R3 redistribute static to other routers. Or set up a relation between R5 and R3 as of OSPF.
BB
router ospf 1
punasup
Thanks guys!
Hello
!router ospf 1
R5
Kind Regards
Paul
