Strange IP Connectivity
Farjad Haider
I configured a lab using the 192.168.0.0/29 subnet on the outside interface of a firewall that is connected to an HSRP setup. Initially, without other devices the subnet works perfectly fine but when i add other configurations and more devices, the subnet suddenly loses connectivity. There are no ACLs applied on the firewall to block connections. The other subnets on the inside interface continue from 192.168.0.0. onwards (Implementing VLSM).
Interestingly, when I change the outside subnet to 192.168.1.0/29, the connections work perfectly fine.
5 Replies 5
balaji.bandi
Until we see the configuration, we do not what is the wrong here.
guide lines, you can not have same subnet inside and outside overlapping.
BB
they are not on the same subnet, the inside is on 192.168.0.8/30 and outside is 192.168.0.0/29.
I forgot to mention when I initially assigned the IPs with only the routers and firewall in the topology, everything worked fine, but when i added other devices and other subnets, it lost connectivity.
BB
Primary Router:
interface GigabitEthernet0/0/0
ip address 192.168.1.1 255.255.255.248
duplex auto
speed auto
standby priority 150
standby preempt
standby 1 ip 192.168.1.3
interface GigabitEthernet0/0/1
ip address 10.0.0.1 255.255.255.248
duplex auto
speed auto
standby 1 ip 10.0.0.3
standby preempt
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
redistribute connected subnets
network 10.0.0.0 0.0.0.7 area 0
network 192.168.1.0 0.0.0.7 area 0
Firewall:
ciscoasa#sh run
: Saved
ASA Version 9.6(1)
hostname ciscoasa
names
interface GigabitEthernet1/1
nameif outside
security-level 0
ip address 192.168.1.4 255.255.255.248
interface GigabitEthernet1/2
nameif inside
security-level 100
ip address 192.168.0.9 255.255.255.252
interface GigabitEthernet1/3
nameif DMZ
security-level 50
ip address 192.168.0.25 255.255.255.252
interface GigabitEthernet1/4
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/5
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/6
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/7
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/8
no nameif
no security-level
no ip address
shutdown
interface Management1/1
management-only
no nameif
no security-level
no ip address
shutdown
access-list INSIDE-ACL extended permit ip 192.168.0.32 255.255.255.248 any
access-list INSIDE-ACL extended permit ip 192.168.0.48 255.255.255.240 host 192.168.0.26
access-list INSIDE-ACL extended permit ip 192.168.0.40 255.255.255.248 host 192.168.0.26
access-list INSIDE-ACL extended deny ip 192.168.0.48 255.255.255.240 any
access-list INSIDE-ACL extended deny ip 192.168.0.40 255.255.255.248 any
access-list INSIDE-ACL extended permit ip any any
access-list OUTSIDE-ACL extended permit ip any any
access-list OUTSIDE-ACL extended permit icmp any any
access-list DMZ-ACL extended permit ip any host 192.168.0.26
access-list DMZ-ACL extended deny ip any any
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect icmp
inspect tftp
service-policy global_policy global
telnet timeout 5
ssh timeout 5
ACLs have not been applied yet.
This configuration somehow helps, but not 100%; we do not have a complete picture of the network.
As per the information firewall, G1/2 Lan side and Gig1/1 Outside to interface ( as per the diagram, is this correct)
I do not see any route in ASA for the outside default route point to HSRP IP 192.168.1.3.
On the router, you are running OSPF. Can you show the IP OSPF ne ? and routing table (show ip route) And is the HSRP working? How does the router know return traffic sent to ASA?
BB
