Strange issue in opening sites (Multilink )
CSCO10758684
Hai All,
One of my customer is facing a strange problem when accessing sites.Customer is running Multilink (4Mbps 2x2).When customer is opening the sites only images are not displayed in the page.Physical media dosent have any issue.Customer VPN is running fine.
customer has done the config changes "no PPP multilink fragment disable "
Have isolated the customer LAN by connecting Laptop directly to Router ... but observed the same issue
Please find the below customer end config
Please help me regarding this
XXXXX#sh run
Building configuration...
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip name-server XXXXXXXXXXXXX
no ftp-server write-enable
interface Multilink1
ip address XXXXXXXXXXXXX
ip nat outside
ppp chap hostname XXXXXXXXXXXXX
ppp multilink
ppp multilink group 1
interface Multilink6
no ip address
load-interval 30
ppp multilink
ppp multilink group 6
interface FastEthernet0/0
ip nat inside
duplex auto
speed auto
interface Serial0/0
bandwidth 2048
no ip address
encapsulation ppp
no ip route-cache
load-interval 30
ppp multilink
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
bandwidth 2048
no ip address
encapsulation ppp
load-interval 30
ppp multilink
ip nat inside source list 1 interface Multilink1 overload
no ip classless
ip route 0.0.0.0 0.0.0.0 Multilink1
ip http server
access-list 1 permit XXXXXXXXXXXXX
dialer-list 1 protocol ip permit
snmp-server community public RO
snmp-server enable traps tty
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
Hieu Cao
Level 4
Level 4
does it happen with ie only? have you tried firefox?
Hai,
Thanks for the reply ....its not happening for safari,firefox and IE ...
Can any one help me regarding this .....absolutly no idea how to go ahead
hai all,
At last the strange issue got resolved.We suspected two things
1)Problem with the WAN $ LAN ip Block.
2)Router/IOS
We created customer set up at our pop.was able to browse(With LAN and WAN Ip ) every thing happening.
We replaced the customer router (Having newer IOS ) .Then thing started working fine,,,
The reason i pasted .....might help in resolving the same type of issue ...(For us it has taken 3 Busness days)
Lijesh.N.c
Bharti Airtel.
