Strange issue with Cisco 2821
alexthegr8
I have a recently acquired Cisco 2821 for my CCNA lab. It is replacing an 1841 which seemed to be bottlenecking my bandwidth. I copied the (working) config from the 1841, and I am able to ping the internet from the router and the LAN.
The strange issue comes to when I try to resolve DNS over the internet. For some reason the router seems to filtering port 53 traffic. I set out to prove this by using nmap. With nmap, I scanned a known DNS server (which has ALL ports blocked except 53) and nmap responded that ports 80, 3128, and 8080 were open. (Which is not the case). I then connected to a different network (with working internet/dns) and performed the scan again. Results confirmed only port 53 was open.
I then also ran a port scan on 8.8.8.8 on the separate network; the results were the same. 53 was unfiltered.
My router config is very simple, all ports are supposed to be open with the given ACL
IOS ver 12.4 (13r)
Current configuration : 2087 bytes
version 12.4
service password-encryption
hostname Reed2821
boot-start-marker
boot-end-marker
enable secret 5 $1$haDp$l7TWsu6gwtm4a21C4e7Z21
enable password 7 01000E055F04111D2848490C
aaa new-model
aaa authentication login local_auth local
aaa session-id common
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.2 10.0.0.15
ip dhcp pool ParDigital
   network 10.0.0.0 255.255.255.0
   dns-server 10.0.0.3 8.8.8.8
   domain-name ParDigital.net
   default-router 10.0.0.1
no ip domain lookup
ip domain name ParDigital.net
username paul privilege 15 password 7 0305570E1E5779
interface Loopback1
 ip address 10.0.0.15 255.255.255.0
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 ip access-group 100 in
 ip access-group 100 out
 ip flow ingress
 ip nat outside
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 ip address 10.0.0.1 255.255.255.0
 ip flow egress
 ip nat inside
 duplex auto
 speed auto
interface Serial0/3/0
 no ip address
 shutdown
router ospf 1
 log-adjacency-changes
 network 10.0.0.0 0.0.0.255 area 0
 network 10.1.0.0 0.0.0.255 area 1
 network 10.1.0.0 0.0.255.255 area 0
 network 107.138.202.129 0.0.0.0 area 0
 network 192.168.0.0 0.0.255.255 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 107.138.200.1 254
no ip http server
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.0.0.81 80 interface GigabitEthernet0/0 80
access-list 100 permit ip any any
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 exec-timeout 0 0
 privilege level 15
 password 7 14041A0A080B3D392D2C3430
 login authentication local_auth
 transport input ssh
line vty 5 15
 exec-timeout 0 0
 privilege level 15
 transport input ssh
scheduler allocate 20000 1000
ntp server 206.246.122.250
end
Bilal Nawaz
Hello, maybe your host is trying to use 10.0.0.3 as its DNS primary server and it doesn't work? Can you maybe change this or check that 10.0.0.3 is serving DNS requests properly.
Or manually change DNS settings on your pc/laptop to point towards 8.8.8.8 or 8.8.4.4 to see if dns works...
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
It still did not. I ended up upgrading to ios15 and everything worked from there. Strange bug
