Strange ppp multilink speed issue
phydoux999
I have a customer using ppp multilink with two T-1s on a Cisco 1721. Running 12.3(16) firmware, 32meg flash 32 meg NVRAM. My customer is accessing a secure www site, that with both T-1s connected the www site is very, very slow. When my customer disconnects one of the T-1s(it does not matter which T-1) the speed of the www site increases 90%.
As I said it does not matter which T-1 is disconnected, the speed changes are the same. We have worked with the www site admins who state they do not see anything wrong. One of my admins suggested upgrading the firmware on the 1720 from 12.2(6c) to the current 12.3(16). This change actualy made the speed worse.
Any suggestions???
lgijssel
Level 9
Level 9
Your connection is proably suffering from out-of-sequence packets. Many application do not handle this well. Best advice I can give is:
1: try to determine if this is indeed happening. You will need a protocol analyser for this.
2: alter the load balancing such that all traffic for one particular session is always routed via the same link.
Leo
We are looking into the protocol analyser option at this time. As for the load balancing we have all traffic routed to the multilink interface.
interface Multilink1
ip unnumbered FastEthernet0
no cdp enable
ppp multilink
no ppp multilink fragmentation
multilink-group 1
interface Serial0
description Connected to
no ip address
encapsulation ppp
no ip route-cache
no fair-queue
ppp multilink
multilink-group 1
interface Serial1
no ip address
encapsulation ppp
no ip route-cache
no fair-queue
ppp multilink
multilink-group 1
ip classless
ip route 0.0.0.0 0.0.0.0 Multilink1
Still I expect an out-of-sequence issue. It would be good if you could confirm this via an analyser trace.
I have looked up some info about ways to get around this:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080110bd7.html#wp1025043
Hope this helps you a bit further
Leo
