STRANGE PROBLEM WITH OSPF
qualxarnu
Dear Community,
I would like to to ask you for a little help or hint regarding the strange issue which I have with the OSPF protocol.
Below I will try to explain how the network topology looks like.
I have few locations which in most cases have two routers. Few of them have only one router.
In main location we have two routers which are DMVPN hubs.
Each router in HQ is a hub for own DMVPN cloud and in branches each router is connected only to one DMVPN hub.
Exception are location with one router which have DMVPN connection to both hubs.
Then each location have also a multilayer switch which has SVI interfaces for specific location.
Now the OSPF is configured in a way that all routers using DMVPN are in area 0 and interface towards the multilayer switch is a normal area. Each location has own area number.
Now the problem is that some multilayer switches doesn't install routes to the routing tables from other areas and I'm not sure what can be the problem.
From things which I checked are:
- all DMVPN routers are in OSPF FULL state with particular DMVPN hub (branch router 1 is in FULL state with hub1, router 2 with hub 2)
- in specific branch location both routers are in FULL state with each other and with multilayer switch
- network type for tunnel interfaces is set to point-multipoint
- all routers in area 0 has information about all subnets in the environment
- databases on multilayer switches however looks kind of suspicious for me.
I aslo tried in two locations to switch from EIGRP to OSPF which should replace the first one, and first branch which has one DMVPN router and multilayer switch it worked like a charm.
But other two locations with two DMVPN routers and multilayer switches didn't go so well.
The problem was that not all routes were installed to the routing table by OSPF o multilayer switches.
What is interesting,both locations have the same type of a switch, the same software version and the same license level (for the first time it was ipbase, then increasedto ipservices - same result).
But for some reason one switch dosent install all routes.
Configurations looks the same I think, but maybe I missed something and maybe there is some reason why it's happening like that.
Can someone give a hint what will be the good/fastest way to check/debug why multilayer switch doesn't install all routes?
I will be really grateful.
41 Replies 41
Have to study your answers further, and the info your provided David, but in your "simplified" diagram, only the area 6 ABR precludes area 0 from being partitioned.
Regarding area 0 continuity, I did small test where I turned off OSPF on the HUB2 router.
So in this case only HUB1 was working, so something which can also happen due to the router failure.
But with only 1 DMVPN hub working it also didn't solve the issue.
Deactivation of a hub, wasn't something I suggested, as it should NOT partition area 0 as long as you have any other router like your area 6 example.
Even if you did partition your area 0, the way you're configured, I'm unsure you would create a problem.
Just for laughs, in a problem area, like one represented by area 2 in your diagram (i.e. two VPN routers), you might try creating secondary area 0 addresses on your VPN routers, on the same interfaces working with the branch area L3 switch (latter not to be given a similar secondary).  This would be somewhat like your area 6 example, but with two branch routers rather that one.
I've still not yet (haven't had the time) to fully analyze the additional information you've provided.  So far, haven't seen a obvious reason why you're having this problem. (To really analyze this, might need to dig into the LSA database.)
One of our great(est) contributors, @Peter Paluch, I believe, is very knowledgeable about many routing protocols, including OSPF.  If he has the time, perhaps he'll join us.
Can you share your configurations and diagram with us. Doesn't have to be the whole thing just a sample of 1 working one and non-working site since you said only some of the L3 switches don't have all the routes.
Some show commands could also be helpful:
show ip ospf int brief
show ip ospf nieghbor
Things to check also.
Make sure the same RID is not being used on more than 1 device. The router/switch will ignore LSUs from its own RUD so if they are conflicting it wont learn the routes
Another thing to check is to make sure your areas are configured correctly. Discontiguous areas can be a problem especially in a DMVPN network
And finally are there any other routing protocols in use that would exclude OSPF form being installed in the routing table such as EIGRP or external BGP?
-David
Simplified topology:
So the areas like area 2 doesn't work, areas like this with number 6 seems to be working. The last varation like area 15 is not checked yet.
Config for HUB1 router:
router ospf 10
router-id 10.100.0.1
priority 100
auto-cost reference-bandwidth 100000
nsf
area 0 authentication
area 1 authentication message-digest
redistribute static metric-type 1 subnets
redistribute bgp 65210 metric-type 1 subnets route-map BGP2OSPF
passive-interface default
no passive-interface GigabitEthernet0/0/0
no passive-interface Tunnel101
network 10.100.0.1 0.0.0.0 area 0
network 10.100.1.0 0.0.0.255 area 0
network 10.101.100.0 0.0.0.255 area 1
default-information originate metric 180 metric-type 1
interface Tunnel101
ip ospf authentication key-chain WAN-OSPF
ip ospf network broadcast
ip ospf priority 100
ip ospf bfd
ip ospf 10 area 0
ip ospf message-digest-key 1 md5 xxxxxxxxxxxxxx
ip ospf dead-interval 15
ip ospf hello-interval 5
ip ospf bfd
ip ospf 10 area 1
WORKING SCENARIO
SPOKE RTR:
router-id 10.100.0.16
nsf
area 7 authentication
redistribute bgp 65228 metric-type 1 subnets route-map BGP2OSPF
no passive-interface Tunnel201
network 10.100.0.16 0.0.0.0 area 0
network 10.100.2.0 0.0.0.255 area 0
network 10.107.100.0 0.0.0.255 area 7
interface Tunnel101
ip ospf bfd
ip ospf 10 area 0
interface Tunnel201
ip ospf authentication key-chain WAN2-OSPF
ip ospf bfd
ip ospf 10 area 0
ip ospf cost 10000
ip ospf authentication key-chain LAN-OSPF
ip ospf priority 50
ip ospf bfd
ip ospf 10 area 7
show ip ospf nieghbor:
Neighbor ID Pri State Dead Time Address Interface
10.100.0.2 90 FULL/DR 00:00:35 10.100.2.1 Tunnel201
10.100.0.1 100 FULL/DR 00:00:39 10.100.1.1 Tunnel101
10.107.100.4 1 FULL/BDR 00:00:13 10.107.100.4 GigabitEthernet0/0/0
show ip ospf int brief:
Interface PID Area IP Address/Mask Cost State Nbrs F/C
Lo1 10 0 10.100.0.16/32 1 LOOP 0/0
Tu201 10 0 10.100.2.8/24 10000 BDR 1/1
Tu101 10 0 10.100.1.8/24 3333 BDR 1/1
Gi0/0/0 10 7 10.107.100.2/24 100 DR 1/1
MULTILAYER SWITCH:
router ospf 10
router-id 10.107.100.4
nsf
no passive-interface Vlan100
network 10.107.0.0 0.0.255.255 area 7
network 192.168.208.0 0.0.0.255 area 7
network 192.168.228.0 0.0.0.255 area 7
interface Vlan100
ip ospf bfd
ip ospf 10 area 7
10.100.0.16 50 FULL/DR 00:00:11 10.107.100.2 Vlan100
Vl228 10 7 192.168.228.5/24 100 DR 0/0
Vl208 10 7 192.168.208.1/24 100 DR 0/0
Vl100 10 7 10.107.100.4/24 100 BDR 1/1
NOT WORKING SCENARIO
SPOKE RTR1:
router ospf 10
router-id 10.100.0.22
nsf
area 10 authentication
redistribute bgp 65224 metric-type 1 subnets route-map BGP2OSPF
network 10.100.0.22 0.0.0.0 area 0
network 10.110.100.0 0.0.0.255 area 10
interface Tunnel101
ip ospf bfd
ip ospf 10 area 0
ip ospf bfd
ip ospf 10 area 10
10.100.0.1 100 FULL/DR 00:00:32 10.100.1.1 Tunnel101
10.100.0.23 50 FULL/BDR 00:00:12 10.110.100.3 GigabitEthernet0/0/0
10.110.100.4 1 FULL/DROTHER 00:00:12 10.110.100.4 GigabitEthernet0/0/0
Lo1 10 0 10.100.0.22/32 1 LOOP 0/0
Tu101 10 0 10.100.1.11/24 10000 BDR 1/1
Gi0/0/0 10 10 10.110.100.2/24 100 DR 2/2
SPOKE RTR2:
router ospf 10
router-id 10.100.0.23
nsf
network 10.100.0.23 0.0.0.0 area 0
interface Tunnel201
ip ospf bfd
ip ospf 10 area 0
ip ospf cost 10000
ip ospf priority 50
ip ospf bfd
ip ospf 10 area 10
ip ospf cost 10000
10.100.0.2 90 FULL/DR 00:00:38 10.100.2.1 Tunnel201
10.100.0.22 100 FULL/DR 00:00:10 10.110.100.2 GigabitEthernet0/0/0
10.110.100.4 1 FULL/DROTHER 00:00:11 10.110.100.4 GigabitEthernet0/0/0
Lo1 10 0 10.100.0.23/32 1 LOOP 0/0
Tu201 10 0 10.100.2.11/24 10000 BDR 1/1
Gi0/0/0 10 10 10.110.100.3/24 10000 BDR 2/2
MULTILAYER SWITCH:
router ospf 10
router-id 10.110.100.4
nsf
network 10.110.0.0 0.0.255.255 area 10
network 192.168.224.0 0.0.0.255 area 10
interface Vlan100
ip ospf bfd
ip ospf 10 area 10
10.100.0.22 100 FULL/DR 00:00:11 10.110.100.2 Vlan100
10.100.0.23 50 FULL/BDR 00:00:11 10.110.100.3 Vlan100
Vl224 10 10 192.168.224.1/24 100 DR 0/0
Vl100 10 10 10.110.100.4/24 100 DROTH 2/2
Regarding few more questions:
- RID should be unique for each router and multilayer switch using OSPF.
- I hope that areas are configured correctly. Each hub and spoke router has tunnel interface in area 0 while LAN interface in specific and unique area. Multilayer switches are only in normal areas (without area 0), but they are connected to these routers which have connection with area 0.
- in case of other protocols, yes there is BGP, but it's used only for private IP address scope which is redistributed to the OSPF. What is more, there is a EIGRP which I would like to replace with OSPF because later I would like to also use dynamic routing on on Cisco devices which are not talking via EIGRP. But in situation where I turn off EIGRP in one scenario OSPF works ok, but in other scenario communication is lost as not all routes are installed in routing table.
To be honest I'm starting to wonder, if in this case if branch has 2 spoke routers, then maybe connection both spokes with both hubs will not solve the issue. However in case of EIGRP the current scenario works fine, so I'm wondering why......
Freind you config ospf priority 100 in hub
That good only clear ip ospf process in not work sites and check again.
@Joseph W. Doherty comment got me thinking with the reference BW cost. Could just be another box checked in the troubleshooting process though. I didn't read everything everyone sent so apologies if there is repetition.
You say the routes are having trouble showing up in some switches - from that we can assume ALL routes are making it to the spoke routers at least? Because the obvious reason it wouldn't be at the switches is the spoke routers don't have the routes so we would need to tshoot that. But if all routes are sucessfully making it to every spoke then try the below:
The max metric of an OSPF link is 65535. So it wont install in the RIB if it hits the max metric. The auto cost configured coupled with default tunnel BW configurations could affect this number.
Can you provide the OSPF LSDB of a Spoke and Multilayer switch that ARE OSPF neighbors but are NOT installing routes.
show ip osp database
and
show ip opsf databse summary
And please indicate which area you pulled this form
So we can see the metric associated with these networks.
-David
Laugh, I just hit reply on my last posting, got an invalid authentication, or some such, refreshed paged, and saw David's posting hitting some of the very issues I was going to bring up, like the high auto reference cost especially along with using manual costs of 10K.
I was going to also ask about EXACTLY what has been appearing, or not, in route tables, along with what looked incorrect about the OSPF database.
BTW, David, "The max metric of an OSPF link is 65535. So it wont install in the RIB if it hits the max metric.", in the past, I recall (?), when I've actually bumped into hitting the max cost for multiple paths, all such were considered equal and were installed.  (I also recall using an IOS version that when you exceeded the number of max OSPF ECMP routes, it would incorrectly compute what should be installed [in my case, though, IOS had been fixed].)
Anyway, I just set up a very small PT environment, with a topology of one spoke area only having one router, and another spoke having two routers.  Did not muck with costs and/or auto bandwidth costing, but, of course, sh ip route and show ip os database look "different" from each of the spoke L3 switches.  Hence, probably worthwhile to fully understand EXACTLY what you believe OSPF is doing incorrectly.
Don't know if it's of any use, but I've attached the PT file.
Very interesting. Ill take a look at the PT file later (if this hasn't been solved as I am curious).
Also just to clarify the max metric was per link. So you could have 2 links each with a cost of 50000 and it would still be ok. In total it would be 100000 but each link was still below the maximum and still valid and installed in the RIB.
Interesting if you hit max metric and still installed anyway but to be fair if they are all the same number even if it is max metric its still an ECMP, maybe a bug or "feature" haha. But still good to know it "can" happen maybe in certain situations.
Specifically looking for 65535 where the TOS metric is 10 in this example:
May be a mute point after what you mentioned though.
But with a summary address since it inter-area. I think like you said we may need full configs to properly tshoot better in this scenario.
BTW
Clarification:
A better description of this issue/situation, might be found here .
As an example, I just configured PT with 4 routers in series, with first having cost of 40,000 and second having cost of 65,535 (max), and from first,
sh ip route:
Gateway of last resort is not set
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, GigabitEthernet0/0/0
L 192.168.1.1/32 is directly connected, GigabitEthernet0/0/0
O 192.168.2.0/24 [110/105535] via 192.168.1.2, 00:00:09, GigabitEthernet0/0/0
O 192.168.3.0/24 [110/105536] via 192.168.1.2, 00:00:09, GigabitEthernet0/0/0
I.e. maximum link/interface cost I could set was 64K, but OSPF did sum the 40K and 65K (and default last link cost of 1) link costs.
Peter Paluch
My friends,
Please allow me to join.
For me, to troubleshoot this issue in the most efficient way, this is the information that would help tremendously:
  • At least one network (address/netmask) that is not installed into RIB in area 2 that we can trace
  • The complete output of the following commands collected from the multilayer switch in area 2 as well as both ABRs (spokes) in area 2:
    • show ip ospf database router
    • show ip ospf database network
    • show ip ospf database summary
    • show ip ospf database asbr-summary
    • show ip ospf database external
    • show ip ospf rib
    • show ip route
Without this, I can only give generic comments based on the information shared so far.
The diagram does not show whether the two DMVPN hubs have an OSPF adjacency between themselves over the Tunnel interface. This is important for two reasons:
  1. If the OSPF network type is broadcast then the two hubs need to hear each other, otherwise they may both end up being DRs which would be illegal.
  2. The area 0 must be contiguous. If there is no other part of area 0 between the hubs that is independent of the Tunnel interface then this adjacency is the only one that guarantees that the area 0 remains contiguous even without any spokes.
Hence, Question 1: Do the DMVPN hubs have an OSPF adjacency in the FULL state with each other across the Tunnel interface?
Further on, according to the partial configurations here, this appears to be a DMVPN Phase2 setup - I do not see "ip nhrp shortcut" and "ip nhrp redirect" commands configured. Different DMVPN phases require different OSPF setups as Joseph has pointed out:
  • DMVPN Phase2 requires the use of OSPF broadcast network type on the Tunnel interface on all hubs and spokes, and also requires the use of "ip ospf priority 0" on all spokes.
  • DMVPN Phase3 requires the use of OSPF point-to-multipoint network type on the Tunnel interface on all hubs and spokes.
Hence,
Question 2: Which DMVPN phase is used in this setup?
Question 3: Is the OSPF configured accordingly for the DMVPN phase in use as described above?
Best regards,
Peter
Peter thanks for joining!!!
Regarding your question whether the two hubs have a tunnel adjacency, believe the answer is no, as each hub only has one DMVPN, each different subnets.
So, I believe your point #1 isn't a "direct" issue, alone. (If I'm mistaken, please correct me.)
As far as I can tell, so far, the only thing that precludes area (zero) partitioning is spokes with single VPN router (IMO far from ideal [i.e. ditto your point #2]).
Joseph,
I am glad to be around : ) Thank you for having me!
Oh, if every DMVPN hub has its own independent Tunnel interface then this is quite a weird design... I missed that. In that case, it is even more relevant to ask what makes the area 0 contiguous in this case. In theory, the area 0 is currently kept contiguous through the spoke router in area 6 but I'm not sure how much detail has been simplified away. We definitely need @qualxarnu to shed more detail on this. Most certainly, keeping the area 0 contiguous through spoke routers is a major no-no. There needs to be another topology put in place to make the area 0 contiguous - even as simple as a dedicated physical link between the two DMVPN hubs. But there must be something added if it's not in place already.
Best regards,
Peter
Hi Peter, Hi Guys,
I'm sorry for my silence. I'm recently busy with some project.
Anyway so far I would like to thank you for all those questions and thoughts, because it's starts to lead me to some conclution which I was suspecting but I was not copletely sure.
So small comment from my side, the environment on which I would like to run the OSPF, it's a company environment and it's something which needs a lot of improvements and which I try to do recently.
For now I had to turn off the OSPF, as it's the production network and I will be able to do some test during the weekend.
So I cannot send you right now all these SHOWs for OSPF, but I can give you some configuration and answer some questions.
Based on what you ALL wrote so far I thing that maybe all spoke routers should have DMVPN tunnel to both HUBs. This is what I thought once it turned out that location with only one spoke, which has tunnels to both hubs, works fine.
However I was not sure, because currently working EIGRP somehow works correctly on this topology.
Second thing is maybe a DMVPN phase, because if I'm ot wrong, currently configured phase is 2 and I thing phase 3 would be better to have in this case.
Ok, so I will first anser some questions and then I will paste some parts of configuration.
1. I've set the network type for broadcast and I saw that both hubs became DRs for own DMVPN cloud.
Previously I did some shows and here is for example router from area where there is only on router connected to both hubs:
10.100.0.1 is a hub1 while 10.100.0.2 is hub2
. Both have different subnet for tunel interfaces.
In case of area 0, it's set only on DMVPN routers and only on the Tunnel interfaces. The LAN interfaces are configured in a normal area where each site has own, unique number of the area.
The DMVPN hubs have FULL adjency with spokes in own DMVPN cloud. So if for example there is a site with two spokes, then one spoke is connected with hub1 where has FULL adjency and spoke2 has FULL adjency with hub2.
The exception occurs where we have only one spoke on sitte. It has FULL adjency with both hubs as it has two separate tunnel interfaces, each having separate subnet and in each subnet the DR is a hub router.
In case of DMVPN phase , like I wrote, it will be phase 2 and I admit that I didn't set priority on spokes. Only on hubs to force them to be the DR routers.
In case of question if the OSPF is configured accordingly to the phase, this is what I  was not sure and that's why I'm here
So I will now paste some configs with more elements for you.
This is the HUB1 configuration:
router ospf 10
priority 100
nsf
interface Tunnel101
bandwidth 1000000
ip address 10.100.1.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication xxxxxxxx
ip nhrp network-id 101
ip nhrp redirect
ip tcp adjust-mss 1360
ip ospf bfd
ip ospf 10 area 0
delay 1000
tunnel source GigabitEthernet0/0/3
tunnel mode gre multipoint
tunnel key 101
tunnel vrf IWAN-TRANSPORT-1
tunnel protection ipsec profile DMVPN-IPSEC-PROFILE
domain iwan path INET1 path-id 1
hold-queue 4096 in
hold-queue 4096 out
ip address 10.101.100.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip verify unicast source reachable-via rx allow-default
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 7 xxxxxxxxxxxxxxx
ip ospf bfd
ip ospf 10 area 1
negotiation auto
router ospf 10
priority 80
nsf
network 10.100.0.2 0.0.0.0 area 0
interface Tunnel201
bandwidth 200000
ip flow monitor FlowMonitor1 input
ip flow monitor FlowMonitor1 output
ip address 10.100.2.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication xxxxxxxxxxx
ip nhrp network-id 201
ip nhrp redirect
ip ospf priority 90
ip ospf bfd
ip ospf 10 area 0
ip ospf cost 10000
delay 1000
tunnel key 201
tunnel vrf IWAN-TRANSPORT-2
domain iwan path INET2 path-id 2
hold-queue 4096 in
hold-queue 4096 out
ip address 10.101.100.3 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf message-digest-key 1 md5 7xxxxxxxxxxxx
ip ospf priority 90
ip ospf bfd
ip ospf 10 area 1
ip ospf cost 1000
negotiation auto
Now the Spoke 1 from area with two spokes:
router ospf 10
nsf
interface Tunnel101
bandwidth 10000
ip address 10.100.1.11 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp nhs 10.100.1.1 nbma 157.161.177.34 multicast
ip ospf bfd
ip ospf 10 area 0
delay 10000
no nhrp route-watch
if-state nhrp
tunnel source GigabitEthernet0/0/1
tunnel key 101
ip address 10.110.100.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
standby 10 ip 10.110.100.1
standby 10 priority 110
standby 10 preempt
standby 10 track 10 decrement 60
ip ospf bfd
ip ospf 10 area 10
delay 25000
negotiation auto
Now the Spoke 2 from area with two spokes:
router ospf 10
shutdown
nsf
interface Tunnel201
bandwidth 10000
ip address 10.100.2.11 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp nhs 10.100.2.1 nbma 212.120.38.169 multicast
ip ospf bfd
ip ospf 10 area 0
ip ospf cost 10000
delay 20000
no nhrp route-watch
if-state nhrp
tunnel key 201
ip address 10.110.100.3 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
standby 10 priority 105
standby 10 preempt
ip ospf priority 50
ip ospf bfd
ip ospf 10 area 10
ip ospf cost 10000
delay 25000
negotiation auto
Spoke from area with only one spoke:
router ospf 10
shutdown
nsf
interface Tunnel101
bandwidth 30000
ip address 10.100.1.8 255.255.255.0
no ip redirects
ip mtu 1400
ip ospf bfd
ip ospf 10 area 0
delay 1000
nhrp group RS-GROUP-30MBPS
no nhrp route-watch
if-state nhrp
tunnel key 101
tunnel protection ipsec profile DMVPN-IPSEC-PROFILE shared
interface Tunnel201
bandwidth 10000
ip address 10.100.2.8 255.255.255.0
no ip redirects
ip mtu 1400
ip ospf bfd
ip ospf 10 area 0
ip ospf cost 10000
delay 20000
no nhrp route-watch
if-state nhrp
tunnel key 201
ip address 10.107.100.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
standby 1 ip 10.107.100.1
standby 1 priority 110
standby 1 preempt
standby 1 track 10 decrement 60
ip ospf priority 50
ip ospf bfd
ip ospf 10 area 7
delay 25000
negotiation auto
Enjoy
In case of new shows like OSPF database, I will be able to send some during the next weekend as I cannot make to much of changes during the week.
Thank you!
