Strange Routing Issue to Internet
samipk1234
Above is my network setup, I have a DMZ zone and then the rest of the LAN. The DMZ is directly connected to fortigate and the rest of the LAN is connected with VLAN 1 of the switch to fortigate, the situation is as below:
  • None of the Client PCS can ping or access the Internet.
  • None of the clients can access 192.168.99.100(The ip of the Fortigate interface on the LAN side.
  • All of the PCS can access 192.168.99.101(The Vlan 1 ip of Core Switch).
  • All of the switches can access Internet as well as 192.168.99.100
  • All of the PCs can access other PCs on other Vlans.
  • The Core Switch Has a default route to 192.168.99.100
  • The Other Switches Have default route to 192.168.99.101(Vlan 1 ip of Core Switch)
  • All PCs have default routes to their respective VLAN ip on Core Switch.
  • The DMZ network PCS can access the Internet perfectly without any issue but the LAN network PCs cant.
I doubt this can be a Fortigate issue as the Switches can access the WAN fine with their 99.0 subnets and they are in the same policy as the rest of the LAN subnets.
How can I allow access to the Internet to LAN Pcs.
Any help is appreciated as I am stuck in this for 2 days and going crazy.
Hello
what makes you think it’s NOT the firewall - if your switchs can access the internet but you vlan clients cannot but can ping each other then it does seem to suggest  to be the FW -
I assume the fw is performing  NAT if so does it’s nat policy include the client vlans
Also does the FW have routing knowledge of the client vlans?
edited - lastly fyi icmp echo-reply could be disabled on the FW so even if you had correct routing you may be not able to ping the FW
Kind Regards
Paul
13 Replies 13
can you post the running config of the Cisco core switch, as well as the config file of the Fortigate ?
Here is the config of core switch
version 15.2
service compress-config
hostname SCore
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode pvst
vlan internal allocation policy ascending
lldp run
interface GigabitEthernet0/0
 switchport mode access
 media-type rj45
 duplex full
 no negotiation auto
interface GigabitEthernet0/1
 switchport mode trunk
 media-type rj45
 duplex full
 no negotiation auto
interface GigabitEthernet0/2
 media-type rj45
 duplex full
 no negotiation auto
interface GigabitEthernet0/3
 media-type rj45
 duplex full
 no negotiation auto
interface GigabitEthernet1/0
 media-type rj45
 duplex full
 no negotiation auto
interface GigabitEthernet1/1
 media-type rj45
 duplex full
 no negotiation auto
interface GigabitEthernet1/2
 media-type rj45
 duplex full
 no negotiation auto
interface GigabitEthernet1/3
 media-type rj45
 duplex full
 no negotiation auto
interface Vlan1
 ip address 192.168.99.101 255.255.255.0
interface Vlan10
 ip address 192.168.10.6 255.255.255.0
interface Vlan30
 ip address 192.168.15.1 255.255.255.0
interface Vlan40
 ip address 192.168.20.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.99.100
control-plane
as for fortigate config do you need the output of show full-configuration???? sorry i am a noob at fortigate.
I have attached images in the original post of the interfaces etc.
which switch model is this ? Usually, a layer 3 switch would have a line 'ip routing' in the config, do you have that enabled ?
Score#conf t
Score(config)#ip routing
It's is an old l3 image of a Cisco switch and yes the IP routing is enabled but not showing up in the config, it also doesn't show the switchport access vlan command but it works.
As I said in the original post all the vlans are able to connect to each other through this switch using IP routing.
All the switches also can ping and access internet using vlan 1 ips just not the client pcs.
can you ping the Fortigate from any of the other SVIs configured on the Cisco ?
How do you propose I do that, as the default route that is connected to fortigate is through vlan 1 ips i.e. .90.0. and to check other svis I might have to define a new route maybe?
Other switches can also access the Fortigate but they are also on vlan 1 so that doesn't count I think.
Sorry but I am still learning so it might be a bit frustrating for you but I am eager to learn.
Hello
on the core switch, type:
ping 192.168.99.100 source vlan x
That basically pings the Fortigate from other vlans. Do you get a response ?
Just checked and no the other SVIs cant ping the 99.100 interface.
Hello
Kind Regards
Paul
Thank you for the reply, I will try to answer your questions in bold below"
What makes you think it’s NOT the firewall - if your switchs can access the internet but you vlan clients cannot but can ping each other then it does seem to suggest  to be the FW -
The subnets of the switches vlan 1 as well as the other vlans are in the same policy definition on the firewall so if one is working the others should too thats why I think its an internal LAN issue.
As stated above yes, I am attaching a pic of the LAN policy and DMZ
The firewall only has 2 simple policy defined, 1 is allowing Lan(All 4 subnets of LAN) to Access Wan and the other is allowing DMZ to allow WAN, the policy is is working for DMZ and the .90.X subnet of LAN but not for anything else
No I have specifically allowed ping request in the policy, pic attached below
EDIT: Also adding another picture of the policy allowing the 99.x series subnet
samipk1234
I Ran a wireshark trace and saw that the packets were getting rejected as they couldnt find the LAN subnets, add a static route back to the LAN ips on fortigate and solved the problem.
Thanks for the help guys.
Hello
congratulations and thanks for the update
Kind Regards
Paul
Hello @samipk1234 ,
thanks for your feedback that provides an happy end to your issue rated as it deserves.
Yes the Fortigate firewall needs static routes for internal LAN subnets with next-hop the core switch IP address on the common IP subnet ( 192.168.99.0 I guess and the next-hop to core switch should be 192.168.99.101)
Best Regards
Giuseppe
