Stupid 7304 config question
admin_2
Level 3
Level 3
So I have a new 7304 with dual NSE 150's. My plan was to plug Gig0 on the hot NSE to G2/1 on my primary core 6500 and Gig0 on the standby NSE to G3/1 on the primary core 6500. Then take Gig1 hot to my secondary core 6500 and Gig1 standby to my secondary core.
Problem is on this monkey I cant configure the standby module so how do I configure the Core connections.
Cant do switchports, the only thing I can think is to do Gig0 hot to Core 1 and Gig0 standby to Core2 with HSRP running on the Core ports.
Does anyone have any config examples for your core connected to a redundant NSE 7300?
Laurent Aubert
From the link below:
"Native Gigabit Ethernet ports not visible or usable on a standby NSE-150. "
http://www.cisco.com/en/US/docs/ios/12_1/12_1ex/feature/guide/12e_rpr.html
Laurent.
