Subnet-to-subnet NAT on Nexus 9K
7tsommer
Hi. I'm trying to do some static NAT on a Nexus 9K and was wondering if there's a way to have it automatically do a one-for-one translation based on subnets instead of host IPs. In other words, I'd like to translate the Outside Global subnet of 192.168.0.x/24 to an Inside Global subnet of 10.0.0.x/24 where .x is the same on both sides. I can already successfully do this with a translation for each host address with a bunch of "ip nat outside source static <outside_global> <outside_local> add-route" commands using host IPs, but I'd like to simplify it by translating the whole subnet. Is this possible on Nexus 9Ks? I do believe there was a "network" keyword on IOS that allowed this, but I don't see it on Nexus.
Note that I can also successfully do the same one-for-one host translation by flipping which interfaces are inside and outside and using "ip nat inside source static <inside_local> <inside_global>" commands (this one doesn't require the "add-route" keyword), so if it's only possible to translate whole subnets one-for-one using inside source, I have that option as well.
6 Replies 6
I dont get totally your Q but
in ip nat pool there is type keyoward which give you two option
A- rotary
B-match host <<- match host make you NAT same host IP, i.e. inside subnet 10.0.0.0 outside subnet 100.0.0.0
the host
10.0.0.1 will NAT to 100.0.0.1 ...etc.
There doesn't appear to be a "type" option at all in the nat pool command on the NX-OS platform.
I will check NSK available command
Yes I check match host is missing from NAT pool in NSK-9000.
thanks
MHM
Hello
Try the following:
ip access-list extended 100
deny ip host 10.0.0.1 any
deny ip host 10.0.0.254 any
permit ip 10.0.0.0 0.0.0.255 any
ip nat pool 1to1_NAT 192.168.0.2 .192.168.0.253 prefix-length 24 type match-host
ip nat inside source list 100 pool 1to1_NAT
Kind Regards
Paul
Unfortunately, I don't think NX-OS includes the "type" or "match-host" keywords in the "ip nat pool" command.
