subnetting cisco packet tracer help
JennisJennis
Hello fellow people. I got a question about Cisco Packet Tracer.
If i have a pc, switch and router, how do i find the ip addresses/vlan/fastethernet etc on them?, how does it work exactly? Because our teacher showed us a method to find the different stuff but I was completely tired and didn't write notes on it which i'm regretting now.
You have to know the pc's address to figure out the rest, don't you? Or perhaps not, I'm not sure.
So far I know how to find the default subway, that's easy enough (Just type in the router's ip address in the PC) but the rest i'm not so sure. Hoping someone can help. Thanks in advance
ammahend
On PC command prompt : ipconfig /all
on switch terminal: show vlan brief
on router terminal : show ip interface brief and show ip route
-hope this helps-
