Suggestion for new implementation
All,
We have existing 3845 Edge router  and 22 Remote location branches all branches have different series of router like ,1800, 2600, 2900 Etc,  now management want to deploye  a new router and the existing (3845 ) router will be for backup , suggest me which series or module of router we can deploye , and our all branches are connecting with MPLS IP-VPN ,
Thanks in Advance for Your suggestions
Syed Aman Hussain,
Edison Ortiz
If the 3845 was meeting your needs what's the reason for the replacement?
The replacement model for the 3800 series is the 3900 series, so if the previous router was adequate enough, go with the 3945.
Edison
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Edison describes, the 3945 is the model that replaces the 3845, however the newer ISRs have more forwarding capacity than those they replace, so depending on your performance needs you might be able to downsize.  See attachment for comparative performance.
