Suggestions - GRE Tunnels
tomfree_leo
Hi Guyz
Here it's my question. Is it possible to configure GRE tunnel with loadbalancing while terminating two ISP link on one router at one end.
Other end with Two Router terminating one isp link.Bandwidth of each ISP is different.
15 Replies 15
Marwan ALshawi
if the Tunnel running between the two switches then yes
but you need to have two default routes in the router with the two links using same metric each one point to one of the ISPs
in the switch connected to two routers there you need your default route to be created and each default route point to one of the routers
but this may lead to asymmetrical routing ( traffic come thorough one ISP and go back through another ISP !!)
good luck
if helpful Rate
What other workable options I got keeping load balancing of bandwidth and link redundancy in mind.
asymmetrical routing will cause serious problem in terms of response time
A dynamic routing protocol like OSPF or EIGRP will auto load balance on path cost and provide redundancy.
HTH>
Tom
Traditional GRE builds a point to point tunnel. So a single traditional GRE tunnel will not work for you in the enviroinment shown in your diagram. There are 2 options I can suggest:
- there is an option to configure multipoint GRE tunnels. This would create a single tunnel on each router and connect a single router at one end and 2 routers at the other end. But this is more complicated to configure and I do not believe that it would facilitate load balancing.
- you could configure 2 GRE tunnels. The single router end would have 2 tunnels on the router and the other end would have a single tunnel on each router. With 2 tunnels it is possible to get load balancing. To get the load balancing to reflect unequal bandwidth can get a bit complex but it is possible.
Rick
[edit]
Andrew
If you configure different bandwidths on the tunnels then PERHAPS EIGRP would load balance and reflect the variation in bandwidth. Running OSPF on tunnels with different bandwidth would generate routes with different costs and OSPF would provide redundancy but not load sharing.
Rick
thanks rburts
2nd suggestion of yours is our preferred option. Whats your opinion on
               1.     running Eigrp on tunnels
               2.     running ospf on lan segment ( currently running on production with single area )
               3.     route-map to control the traffic flow
Bandwidth on tunnels are unequal, I am not aware of which parameter to adjust to get loadsharing and redundancy working.
Rick,
Agreed - however I must admit I jumped in before reading and comprehending the whole requirement.  EIGRP & OSPF will load balance across the GRE tunnels at the HUB end.  Yes you can mess with the Bandwith on the GRE tunnels - as by default they are virtual and have a BW of 9Kb, I personally tinker with the delay to get equal cost LB in EIGRP, another way would be to adjust the variance.  OSPF - agreed is just BW.
From seeing the diagram - did not see it before, I would create the 2 GRE tunnels on either end of the Layer 3 switches (not the routers - that way it would LB @ both ends.
JMTPW
gandrath.nithin
Hello Tom ,
Its possible to loadbalance .
Thanks ,
Nithin Kumar Gandrath
Hello
Can I get config help on variance and tuning of cost for load balancing. I am ok with configuring GRE tunnels, EIGRP basic, OSPF basic, redistribution basic
Variance should only be used - when you are traversing links of different speeds/bandwidth - and you want to multiply the best metric to encompass slower link speeds.
The default BW of a GRE tunnel is 9Kb - unless you have changed this, EIGRP/OSPF will calc the metrics for both tunnels as the same.  You should not need to change anything - unless you have changed the defaults?
thanks prince
I am still not clear how loadbalancing will work as bandwidth are unequal and tunnels will terminate on different routers for redundancy,
I add more details to get more input from you
Location A
ISP_1 terminates on R1 with Bandwidth 6MB
ISP_2 terminates on R2 with Bandwidth 1MB
Location B
ISP_1 terminates on R1 with Bandwidth 2MB
ISP_2 terminates on R1 with Bandwidth 1MB
On Location_A
R1=  GRE_Tunnel 1 will be configured on ISP_1 with Location_B ISP_1
R2 = GRE_Tunnel 2 will be configured on ISP_2 with location_B ISP_2
can you input plz
Your information does not match the diagram you supplied on your initial post.
Prince,
the diagram is without IP but rest is the same.
My apology if it misguided.
Tom my first name is Andrew.
From your earlier post......
Location A
Location B
Your diagram does not show:-
1) Location A
2) Location B
3) Location A R1
4) Location A R2
5) Location B R1
Which site is the hub/core site?
Have you actually configured any of the tunnels?
Have you got a routing protocol running over the 2 sites?
What protocol are you using?
Thank you Andrew,
* Location_A  ( Hub with 2 Routers )
Note sure if its call Dual Head VPN on Same Site
* tested in labs
* on LAN its already OSPF
* for Tunnels planning for EIGRP
For Lan its already OSPF
