Sup2T is not booting after deleting vlan.dat file
Rasika Nayanajith
Hi Guys,
We have recently purchased new Sup2T to replace the Sup720. When we tried to copy the vlan.dat file across we are facing this issue. Sup2T is not booting up once delete the  original vlan.dat file  of the Sup2T & reload.  Here is the console output during the process. Can anyone help what to do to get this Sup2T working.
Router#delete const_nvram:vlan.dat
Delete filename [vlan.dat]?
Delete const_nvram:vlan.dat? [confirm]
Router#
Router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]y
Resetting .......
System Bootstrap, Version 12.2(50r)SYS2, RELEASE SOFTWARE (fc1)
Copyright (c) 2011 by cisco Systems, Inc.
PYRAMID platform with 2097152 Kbytes of main memory
Autoboot: failed, BOOT string is empty
Autoboot executing command: "boot "
bootdisk:%s72044-atafslib-m: Digitally Signed Release Software with key version A
Initializing ATA monitor library...
string is bootdisk:s2t54-adventerprisek9_npe-mz.SPA.150-1.SY.bin
bootdisk:s2t54-adventerprisek9_npe-mz.SPA.150-1.SY.bin: Digitally Signed Release Software with key version A
Self extracting the image... [OK]
Self decompressing the image : ###################################################################################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6506-E (M8572) processor (revision ) with 1769472K/262144K bytes of memory.
Processor board ID SAL16074ER8
CPU: MPC8572_E, Version: 2.2, (0x80E80022)
CORE: E500, Version: 3.0, (0x80210030)
CPU:1500MHz, CCB:600MHz, DDR:600MHz
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from s/w reset
1 Virtual Ethernet interface
30 Gigabit Ethernet interfaces
36 Ten Gigabit Ethernet interfaces
2543K bytes of non-volatile configuration memory.
CONSOLE DOES NOT GIVE ANY THING FROM THIS POINTS ONWARDS
******* WHEN WE BOOT FROM ROMMON MODE, IT WILL GIVE FEW MORE LINES,NOTHING AFTER ************
rommon 5 > dir disk0:
disk0:%s72044-atafslib-m: Digitally Signed Release Software with key version A
Directory of disk0:
3      69552532  -rw-     s2t54-adventerprisek9-mz.SPA.122-50.SY.bin
rommon 6 > boot disk0:s2t54-adventerprisek9-mz.SPA.122-50.SY.bin
disk0:s2t54-adventerprisek9-mz.SPA.122-50.SY.bin: Digitally Signed Release Software with key version A
Self decompressing the image : ##################################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
export@cisco.com.
27 Gigabit Ethernet interfaces
34 Ten Gigabit Ethernet interfaces
WARNING: "ip multicast-routing" is not configured,
           IP Multicast packets will not be forwarded
collect ipv4 version
% Invalid input detected at '^' marker.
Peter Paluch
It seems that the console becomes stuck after the Sup starts to load the configuration file (assuming from the fact that the switch complains about the lack of "ip multicast-routing" command which confirms that the startup-config is being processed). Can you set your configuration register to 0x2142 in the ROMMON and try booting this way? This should prevent the switch from loading the configuration file that perhaps has some troubles starting.
Best regards,
Peter
Peter Paluch
Best regards,
Peter
Hi Peter,
Thanks for the suggestion, yes it worked indeed.
Once bypass the NVRAM, we have deleted the corrupted startup config & apply config from fresh.
Rasika
