Showing results forĀ
Search instead forĀ
Did you mean:Ā
SUP720 in VSS LED status
jack samuel
The LED status on SUP 720 in VSS  is different for IOS SXH and SXI ?????????
i had configured VSS on IOS SXI4a the standby SUP SYSTEM LED is amber,when i pull down the active switch the standby comes up and the amber changes to green.VSS working fine no issues.
BUT
Also i had configured VSS on IOS SXH8a, the STANDBY SUP all LED's are green including the SYSTEM. But the VSS is working fine no issues, Is this is normal or any missing configuration.
Thanks.
2 Accepted Solutions
Richard Michael
Hello Jack,
The VSS Standby "Active" LED should be Amber / Orange (to indicate that it is NOT the Active Supervisor):
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Module_Installation/Sup_Eng_Guide/02superv.html#wp1080351
The active led you see on SXI image is correct. The sup on the active switch should be green and on the standby, it should be amber.
There is a software issue with the led in SXH release. Basically, the LED on the sup does not show the correct status.
Refer Bug ID : CSCso72250
In both the cases, the performance of the VSS is unaffected its just the LED status change between two codes.
Ricky Micky
* Rate useful posts
Hello Jack,
There are multiple ways to search bug in system.
1) You can search in the release notes for the specific IOS train and look for open caveats.
2) Try searching for the bug in the below tool,
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
and if you are interested in certain topic or certain bug try subscribing to it so that you will receive frequent updates as the bug progress. Below link for registration
http://www.cisco.com/cisco/support/notifications/addedit.html
Ricky Micky
*Rate useful posts
Richard Michael
Hello Jack,
Ricky Micky
* Rate useful posts
Tx Richard,
How we will come to know the BUGs, Can u route me to the page where cisco places all information of bugs for IOS and devices.
Tx
Hello Jack,
Ricky Micky
*Rate useful posts
tx,
Hope to see u again in next post.
