supervisor engine issue
harisapkota123
Dear All,
I have a Cisco Catalyst 4003 series switch with WS-X4012 supervisor engine installed on it. When I looked at the LED indication of the module, if found
it has turned from green to amber which seems there is an issue with this module.
Apreciate if someone could explain "in which case it goes to amber."
Further, Any solution regarding this is highly appreciated.
Thanks  in Advance
Leo Laohoo
Gosh, I haven't touched CatOS for a long time.
Can you post the output to the command "sh module"?
Sure, I will provide it. I need to fix it at earliest.
On Tue, May 15, 2012 at 4:18 PM, leolaohoo <
