The problem with cisco 1841.
villi1977
We can not see mac of client on our side some time.
interface GigabitEthernet0/1.2361
description Shindler Riyadh
encapsulation dot1Q 2361
ip address 77.87.17.129 255.255.255.252
ip broadcast-address 0.0.0.0
rate-limit input 2048000 256000 384000 conform-action transmit exceed-action drop
rate-limit output 2048000 256000 384000 conform-action transmit exceed-action drop
core2-jed-gw2#sh ip arp | include 2361
Internet  77.87.17.129            -   0013.801d.aa31  ARPA   GigabitEthernet0/1.2361
We can not see mac address of client 77.87.17.130 now.
Solution:
We use teamviewer with console access via 3g.
We can see mac address of isp(77.87.17.129) on client side.
We try to ping 77.87.17.129 but it's not working.
After 2 min ping is working.
ping starting is working after ping from client side only.
I mean from ips side we try to ping but isn't working one hour,one day.
We tried install ip 77.87.17.130 255.255.255.252 on laptop on client it's working every time.
ShindlerRiyad#sh ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  192.168.40.1            -   001c.58dc.1fa5  ARPA   FastEthernet0/1
Internet  77.87.17.130            -   001c.58dc.1fa4  ARPA   FastEthernet0/0
Internet  77.87.17.129          104   0013.801d.aa31  ARPA   FastEthernet0/0
The client have a settings:
System image file is "flash:c1841-advipservicesk9-mz.124-23.bin"
Current configuration : 1531 bytes
version 12.4
hostname ShindlerRiyad
boot-start-marker
boot system flash c1841-advipservicesk9-mz.124-23.bin
boot-end-marker
enable secret 5 xxxxxxxxxx
aaa new-model
aaa authentication login default local
aaa session-id common
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.40.1 192.168.40.20
ip dhcp pool CLIENT
   import all
   network 192.168.40.0 255.255.255.0
   dns-server 77.87.16.10
   default-router 192.168.40.1
   lease 0 2
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username admin privilege 15 secret 5 xxxxxxxx
interface FastEthernet0/0
ip address 77.87.17.130 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.40.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 77.87.17.129
no ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet0/0 overload
access-list 100 permit ip 192.168.40.0 0.0.0.255 any
control-plane
line con 0
privilege level 15
line aux 0
line vty 0 4
privilege level 15
scheduler allocate 20000 1000
end
villi1977
Peoples please help.
Help please.
The ptoblem was resolved with laster ios version.
