Support of UDP flooding
mlchan
I have the following queries for NPE-G1 in handling UDP flooding from LAN to PA-A3:
1. Can NPE-G1 support flooding of UDP broadcasting traffic received from LAN to remote sites through a PA-A3 with 250 PVCs each at 256kbps?
2. Will the traffic be queued in NPE-G1? If yes, how does NPE-G1 buffer and queue the traffic for forwarding to PA-A3 module with 250 PVCs.
mchin345
Level 6
Level 6
yes, udp flooding is supported on NPE-G1 with PA-A3.
