Supported Module by ASR1002-X
MKH
Hello
Does cisco ASR1002-X router support module with part number SPA-2XOC3-POS-V2 and  SPA-2XOC3-POS?
Can I find compatible module for ASR1002-X
Thank you.
e.ciollaro
Level 4
Level 4
It tried to config a 1002x on CCW with this card and the config has been validated so I suppose they are compatible (see attachment).
To be sure try to check here: https://www.cisco.com/c/en/us/support/routers/asr-1002-x-router/model.html
(click on "Compatible interfaces and modules" to expand and see compatible items)
Check also this:
https://www.google.it/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiny4bL7fLWAhXDQBQKHb-aBScQFggpMAA&url=https%3A%2F%2Fwww.cisco.com%2Fc%2Fdam%2Fen%2Fus%2Fproducts%2Fcollateral%2Fapplication-networking-services%2Fwide-area-appli...
Bye,
enrco
PS: please rate if useful
