Switch 3650 boot in bundle mode, need to convert in install mode
razeev rohilla
Switch boot in bundle mode. Please advice to boot in classic ios mode. it showing only
.pkg
files in flash.
switch: dir flash:
Directory of flash:/
46465 drwx 4096 .
2 drwx 4096 ..
46466 -rw- 83293932 cat3k_caa-base.SPA.03.06.06E.pkg
46467 -rw- 3982012 cat3k_caa-drivers.SPA.03.06.06E.pkg
46468 -rw- 33788908 cat3k_caa-infra.SPA.03.06.06E.pkg
46469 -rw- 43074880 cat3k_caa-iosd-universalk9.SPA.152-2.E6.pkg
46470 -rw- 28394380 cat3k_caa-platform.SPA.03.06.06E.pkg
46471 -rw- 111233856 cat3k_caa-wcm.SPA.10.2.160.0.pkg
46472 -rw- 1236 packages.conf
77441 drwx 4096 dc_profile_dir
46473 -rw- 2097152 nvram_config
46474 -rw- 1576 vlan.dat
1313103872 bytes available (334790656 bytes used)
switch: del flash:config.text
Are you sure you want to delete "flash:config.text" (y/n)?y
File "flash:config.text" not deleted -- read only file system
switch: del flash:vlan.dat
Are you sure you want to delete "flash:vlan.dat" (y/n)?y
File "flash:vlan.dat" not deleted -- read only file system
switch: boot
Getting rest of image
Reading full image into memory...Check base package header ...: done = 16384
Reading full image into memory....done
Reading full base package into memory...: done = 83293932
Bundle Image
Kernel Address : 0x5343234c
Kernel Size : 0x41852f/4293935
Initramfs Address : 0x5384a87c
Initramfs Size : 0xe7766d/15169133
Compression Format: .mzip
Bootable image at @ ram:0x5343234c
Bootable image segment 0 address range [0x81100000, 0x82140000] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 377
Loading Linux kernel with entry point 0x8166a600 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
All packages are Digitally Signed
Starting System Services
FIPS(NGWC): Flash Key Check : Begin
FIPS(NGWC): Flash Key Check : End, Not Found, FIPS Mode Not Enabled
MCU type = 2 and image name is main_mcu_ucode_bundle_8_1_0.tar
Final tar file: main_mcu_ucode_bundle_8_1_0.tar
Front-end Microcode IMG MGR: found 1 microcode images for 1 device.
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_8_1
Front-end Microcode IMG MGR: Preparing to program device microcode...
Front-end Microcode IMG MGR: Preparing to program device[0]...83664 bytes.
Front-end Microcode IMG MGR: Programming device 0...
% Front-end Microcode IMG MGR: address 0, Could not enable sys_poll
% Front-end Microcode IMG MGR: unable to program device: 0
% Front-end Microcode IMG MGR: malformed microcode cache
Jun 17 09:52:21 %PLATFORM_MGR-1-PLATMGR_INIT_FAIL: Platform ManaJun 17 09:52:21 %IOSXE-3-PLATFORM: process sysmgr: Service [platform_mgr] pid:[6027] terminated abnormally [6].
Jun 17 09:52:21 %STACKMGR-1-RELOAD: Reloading due to reason
Jun 17 09:52:22 %IOSXE-2-PLATFORM: process ng_dumper: Process platform_mgr: terminated abnormally.
Jun 17 09:52:23 %IOSXE-2-PLATFORM: process platform_mgr: ===================== Exception Data ====================
Jun 17 09:52:23 %IOSXE-2-PLATFORM: process platform_mgr: Exception in 'platform_mgr' with Signal=SIGABRT(6)
Jun 17 09:52:23 %IOSXE-2-PLATFORM: process platform_mgr: Frame Pointer=0x7F7ED420, Program Counter=0x2C5E33B0
Jun 17 09:52:23 %IOSXE-2-PLATFORM: process platform_mgr: Thread ID=6027: -Traceback= 1#488249e9d04d3bc04e066fb31efe7654 pthread:2C5D1000+123B0
<Sat Jun 17 09:52:21 2023> Message from sysmgr: Reason Code:[2] Reset Reason:Service [platform_mgr] pid:[6027] terminated abnormally [6].
Service: platform_mgr
Description: 3K Platform Manager
Executable: /tmp/sw/mount/cat3k_caa-platform.SPA.03.06.06E.pkg//usr/binos/bin/platform_mgr
Started at Sat Jun 17 09:51:15 2023 (400956 us)
Stopped at Sat Jun 17 09:52:21 2023 (943159 us)
Uptime: 1 minutes 6 seconds
Start type: SRV_OPTION_RESTART_STATELESS (23)
Death reason: SYSMGR_DEATH_REASON_FAILURE_SIGNAL (2)
Last heartbeat 0.00 secs ago
PID: 6027
Exit code: signal 6
CWD: /var/sysmgr/work
PID: 6027
UUID: 3008
Unmounting ng3k filesystems...
Unmounted /dev/sda3...
Warning! - some ng3k filesystems may not have unmounted cleanly...
Please stand by while rebooting the system...
Restarting system.
25 Replies 25
In ROMMON, the command is
emergency-install usbflash0:IOS_filename.bin
razeev rohilla
usb not supported. please tell me how can i format pendrive from switch in rommon mode.
switch: format usbflash0:
Format of filesystem
usbflash0:
not supported!
Format is only used in the flash.  Cannot use it anywhere else.
razeev rohilla
so what method i used to do ios installation. because if i go for
tftp/xmodem
installation lan port not blinking in switch when lan cable connected to laptop. laptop lan is ok tested.
Please READ.
razeev rohilla
not understand, that's why i am seeking help here.
Leo Laohoo
Put the firmware in a USB and then use the command
emergency-install usbflash0:filename.bin
razeev rohilla
Hi Leo,
after running emergency install command. it produce some unexpected errors. and return to previous stage. below is the outcome.
switch: emergency-install sbflash0:cat3k_caa-universalk9.16.12.08.SPA.bin
nknown cmd: emergency-installusbflash0:cat3k_caa-universalk9.16.12.08.SPA.bin
switch:
switch:
switch:
switch: emergency-install usbflash0:cat3k_caa-universalk9.16.12.08.SPA.bin
Unknown cmd: emergency-install
usage: emergency-install url://<url>
switch: dir usbflash0:
Directory of usbflash0:/
4 -rw- 480570202 cat3k_caa-universalk9.16.12.08.SPA.bin
30286659584 bytes available (480641024 bytes used)
The bootflash will be erased during install operation, continue (y/n)?y
Starting emergency recovery (usbflash0:cat3k_caa-universalk9.16.12.08.SPA.bin)...
Reading full image into memory.......................done
Bundle Image
Kernel Address : 0x537995d4
Initramfs Address : 0x53bb1b04
Initramfs Size : 0xe77ac6/15170246
Bootable image at @ ram:0x537995d4
File "sda9:cat3k_caa-recovery.bin" uncompressed and installed, entry point: 0x8166a600
Initiating Emergency Installation of bundle usbflash0:cat3k_caa-universalk9.16.12.08.SPA.bin
Reading bundle usbflash0:cat3k_caa-universalk9.16.12.08.SPA.bin...
Validating bundle usbflash0:cat3k_caa-universalk9.16.12.08.SPA.bin...
Installing bundle usbflash0:cat3k_caa-universalk9.16.12.08.SPA.bin...
Verifying bundle usbflash0:cat3k_caa-universalk9.16.12.08.SPA.bin...
Package cat3k_caa-guestshell.16.12.08.SPA.pkg is Digitally Signed
Package cat3k_caa-rpbase.16.12.08.SPA.pkg is Digitally Signed
Package cat3k_caa-rpcore.16.12.08.SPA.pkg is Digitally Signed
Package cat3k_caa-srdriver.16.12.08.SPA.pkg is Digitally Signed
Package cat3k_caa-webui.16.12.08.SPA.pkg is Digitally Signed
Preparing flash...
Syncing device...
Emergency Install successful... Rebooting
Restarting system.
Booting...
Interface GE 0 link down***ERROR: PHY link is down
The "IP_ADDR" environment variable is not set.
Reading full base package into memory...: done = 32791733
Bundle Image
Kernel Address : 0x537793c4
Kernel Size : 0x4381df/4424159
Initramfs Address : 0x53bb15a3
Initramfs Size : 0x1ab4f12/28004114
Compression Format: mzip
Bootable image at @ ram:0x537793c4
Bootable image segment 0 address range [0x81100000, 0x81da5280] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 623
Loading Linux kernel with entry point 0x81895bf0 ...
Linux version 4.9.187 (sumikum7@sjc-ads-5670) (gcc version 5.3.0 (GCC) ) #1 SMP Fri Nov 19 03:09:46 PST 2021
CVMSEG size: 2 cache lines (256 bytes)
Cavium Inc. SDK-5.1.0
bootconsole [early0] enabled
CPU0 revision is: 000d900a (Cavium Octeon II)
Checking for the multiply/shift bug... no.
Checking for the daddiu bug... no.
%IOSXEBOOT-a5d0a45363676f12d25f956ac5d347ad-new_cksum: (rp/0): 4
%IOSXEBOOT-a5d0a45363676f12d25f956ac5d347ad-saved_cksum: (rp/0): 4
i2c-octeon 1180000001200.i2c: unhandled state: 0
RMA the switch.
razeev rohilla
Hi Leo,
Thanks much for you precious help. I will do that.
I get to learn a lot from you. Thanks again.
Mark Elsen
             - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva30394
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
