Switch broadcast
mangesh_extc
how to check broadcast received on a port.
Ganesh Hariharan
Hi Mangesh,
If you want to check broadcast frome arriving in switch port just make that port to sniff the traffic of the network and you will find a frame with a hexadecimal MAC address of FF-FF-FF-FF-FF-FF. This hexadecimal address is equivalent to 48 binary “ones.”
The meaning of this address in Ethernet is simply that this frame is intended to be received and processed by every node on the network of computers. Broadcast frames are generated when certain network services need to make announcements to other hosts on the network.
Hope it will help out your query !!
If helpful do rate the valauble post.
Ganesh.H
Ganesh Hariharan
Hi Mangesh,
Ganesh.H
Thanks Ganesh
But how can check it from my machine if my machine is connected to that switch and I have no access to switch.
Thanks Ganesh
Hi Mangesh,
You cannot check unless you dont have access to switch that your pc is connected to which switch port by issuong show arp command in switch. Yes you can do  arp -a in command prompt if the swicth is given an ip address of the vlan in which your pc is connected then you can see the ip of the switch.
Hope to help
Ganesh.H
Mohamed Sobair
Level 7
Level 7
You could use any software tools like (wireshark) for example to pin point the location of the broadcast, however, you have another option is to check the Switch interface itself, it should show you number of broadcast packets recieved on a port by issuing normal command (show interface x ).
Mohamed
