Switch C3560 dead, but power supply is on and fan system is on
ekohandri123
i have problem with my cisco C3560x 24 port POE
Led indicator is dead but PSU normal and fan system ok
5 Replies 5
Leo Laohoo
¯¯\_(ツ)_/¯¯
you can connect console cable and check for any output. if there is any error messages, you can get some idea what is happening. if there is nothing comes out in terminal using different working console cables, ... check first
Good luck
KB
nothing come out in terminal, i have been try some cable and i sure my cable is good
               - The device is broken (hardware fault) , have it replaced (RMA)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
If you see PSU on, its completly dead, as suggested connect console and check is there any input you see if not TAC for RMA.
BB
