Switch capa 3 no responde ping
maronetquiroga
Hola !
Acabo de instalar un switch Cisco ME 3400 Capa 3, tengo que utilizar la interface gigaethernet para vincular con fibra a otro equipo, y luego salir con por un puerto fastethernet a mi red.
El tema es que realice la configuracion de el switch, asignandole una ip a cada interface, todo sin problemas, pero cuando me conecto con la computadora directamente a el puerto que asigne, le tiro ping y no responde, como duda hice un ping al broadcast para ver si me lo cargaba en la tabla ARP y asi fue, la ip de el switch figuraba en mi arp.
No puedo hacer que funcione, me podrian orientar?.
saludos
9 Replies 9
burleyman
Level 8
Level 8
What??
burleyman, que no entendiste?.
El problema en si, es que no tengo ping entre la Interface FastEthernet0/1 y la PC conectada directamente, no responde a los ping, ambas se encuentran en la misma subred.
Your post is not in english....can't read it sorry.
Mike
English Translation
burleyman, you did not understand?.
The problem itself is that I have not ping between the Interface FastEthernet0 / 1 and the PC connected directly, does not respond to ping, both are on the same subnet.
Vishesh Verma
Google Translation of the problem -
Hola !
saludos
Hello!
I just installed a Cisco ME 3400 Layer 3 interface I have to use the fiber gigaethernet to link to another computer, and then come out with a fastethernet port to my network. The issue is that you make the switch settings, by assigning an ip to each interface, all without problems, but when I connect the computer directly to the port you assign, you ping shot and unresponsive, as I doubt ping the broadcast to see if I was carrying in the ARP table and so it was, the IP of the switch was on my arp. I can not make it work, I could guide?.
regards
My suggestion -
Please see if your switch's arp is complete -
show ip arp (IP-address of computer)
show mac-address-table | i (mac-address of your computer)
debug ip arp
Spanish Translation -
Por favor, si arp del interruptor está completa -
show ip arp (IP-address de la computadora)
show mac-address-table | i (mac-address de la computadora)
debug ip arp
Hola. gracias por responder !
Realice los comandos:
show ip arp y logro ver la IP y MAC de mi PC,
es raro lo que me esta sucediendo, puede que alguna seguridad o algo este protegiendo las consultas del PING ?, ya reinicie a fabrica el equipo y lo volvi a configurar y sigue igual, no trabajo con VLAN ni nada, solo necesito utilizar la interface de Fibra optica y una FastEthernet con un ruteo estatico.
Traduccion:
Hello. thanks for responding!
Perform the commands:
show ip arp and fail to see the IP and MAC of my PC,
is rare what is happening to me, maybe some security or something that protecting PING queries?, and restart to make the equipment and went back to set up and still the same, do not work with VLAN or anything, I just need to use the interface optical fiber and FastEthernet with static routing.
It can't be a security issue, as your arp is not complete on switch; it could possibly a physical issue maybe incorrect cable.
Please refer to following link for more information of physical connectivityon Cisco ME 3400
No puede ser un problema de seguridad, ya que su arp no es completa en el interruptor, sino que podría, posiblemente, un problema físico cable tal vez errónea.
Consulte la siguiente enlace para obtener más información de física connectivityon Cisco ME 3400
Saludos
http://www.cisco.com/en/US/docs/switches/metro/me3400/hardware/installation/guide/3400hig.pdf
Gracias por responder,
Ahora voy a verificar el archivo que me envio y veo la conectividad, aunque no creo que pase por ahi el problema ya que probe con otros cables utilizando las dos normas ( Cable recto y cruzado) .
Thanks for responding,
Now I will check the file you sent me and see the connectivity, although I do not go out there the problem as probe with other cables using the two standards (straight and cross cable), similarly activate the AUTO MDIX.
maronetquiroga
Thank you very much for trying to help, and I could not problem solve.
I was missing the command ip routing
