Switch info required
dixonphilip
Switch with 24 10/100 ports + 2 GB Ethernet ports, what will be the maximum through put in mbps at any point of time?
What is the suggested switch which could handle around 2GB data at any point of time?
is there any way to convert mpps to mbps?
Pavel Bykov
Level 5
Level 5
There is no normal way to convert mpps to mbps, since packets can have different sizes.
Rule of thumb is to multiply MPPS by 1000, which would correspond to 125 byte packet.
The switch you are looking for is 2960, the WS-C2960-24TC-L
Hope this helps.
Please rate all helpful posts.
shiva_ial
may be etherchannel configuration
if i have understand ur question properly
sarfaraz1981
hi
if u wnat to have 2 gb throug put, its better to configure ether channel on the switch .
Ether channel would be solution.
